need help hitachi super cell MILLING SPINDLE POSITION ERROR #2140
Results 1 to 2 of 2
Thread: need help hitachi super cell MILLING SPINDLE POSITION ERROR #2140
    May 2017
    Default need help hitachi super cell MILLING SPINDLE POSITION ERROR #2140
    Just moved machine into shop a couple weeks ago. Was having some issues with tool change and home position. Machine came with low batteries and was getting alarm for that, think it was ATC battery alarm. Batteries finally arrived and I changed them out with power still on. Went to home machine and got Y and Z home alarms, went to partameter 1815 and 4bit was 0 instead of 1 on both of those. went thru procedure to change to 1 and was able to get all axis home. now on to do a tool change, was going fine until arm change and looks like Y is out about an inch or so. moved back arm and now getting a MILLING SPINDLE POSITION ERROR #2140. Can't find info on how to clear this now...
    Member shas595's Avatar
    Dec 2009
    Default Re: need help hitachi super cell MILLING SPINDLE POSITION ERROR #2140
    Good morning - what is the model / control. If the batteries are low you lost the home positions for the ATC more than likely - let me know and Ill help you out
    John
