Newbie 20slldoes not feed
Results 1 to 2 of 2
Thread: 20slldoes not feed
    Oct 2017
    Default 20slldoes not feed
    20 S ll CNC lathe need to know machine does not feed moves in the rapid travel only any information will help thank you
    Member shas595's Avatar
    Dec 2009
    Default Re: 20slldoes not feed
    So when you press rapid plus a direction it moves but not if you hold only the direction? Make sure your feedrate knob is not turned all the way to zero (not feedrate override, but actual feedrate). You have to be in jog mode as well. When changing the feedrate you should see it on the screen as well.
    Let me know
    John
20slldoes not feed
20slldoes not feed
