Need Help! Hitachi Seiki 5NF-800 - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 54
Thread: Hitachi Seiki 5NF-800
  1. #21
    Registered JeanLuiz's Avatar
    May 2017
    Default Re: Hitachi Seiki 5NF-800
    I think this picture help us!
  2. #22
    May 2017
    And this!
  3. #23
    May 2017
    I found my trouble!
  4. #24
    May 2017
    But this not fix my spindle stop!
  5. #25
    Member shas595's Avatar
    Dec 2009
    What do you mean you found the trouble? What you have circled is a overload for the Motor-Starter (Magnetic Contactor) - what is wrong with it?
  6. #26
    May 2017
    The problem is the contractor and magnetic contractor too, we goes to change! Do you think is different problem? Because when I change the disc position in magnetic contact the trouble off. When I change I talk to you. I’m waiting for buying.
  7. #27
    Dec 2009
    If your machine is on and in standby that contactor should be in. It is either overloaded (hence the THAL alarm) or its dead. It does not look tripped, so if you turn it up and it works it could be dying - would be a good idea to replace both the overload and the contactor itself.
    John
  8. #28
    May 2017
    In this same machine, my spindle don’t move and I have a big contactor there is need to turn on. The both side of contractors coil have power! Why don’t torn on? Because if I take off and test, everything ok! Do you think is trouble in this contact???
  9. #29
    May 2017
  10. #30
    May 2017
    Hello, I change my contactor but the alarm still there! what happens?
  11. #31
    Dec 2009
    One of your overloads is tripped - eithe OL1 OL2 or OL3 - have you checked them all, trip and reset them?
  12. #32
    May 2017
    I did it! But no work!
  13. #33
    May 2017
    Quote Originally Posted by JeanLuiz View Post
    QqqqqqqqqQqqQqqqqqqqqqqqqq
    Sent fromqqqq qqqqqqqqqqqqqqqqqqqqqqQ iPhone using Tapatalk
    QqqqqqqqqqqQqqqqqqqqqqQqqqQQqQqqqqqqqqqqqqqqqqqqqq qqqqqQQqqqqqqqqqqqqqqqqqqqqQqqQQqqqqqqqqqQqQqqqqqQ qQQqqq
    Qqqqqqqqqqqqqq
  14. #34
    May 2017
    Hello everybody! Someone know what it’s mean? Is a error or a kind of stop machine? Please!
  15. #35
    May 2017
    Someone have a Alarm Display List for Micon-8 ????
  16. #36
    Dec 2009
    Mode 29 is status of certain M Codes - Mode 28 will list any present alarms. Can you get it to mode 28
  17. #37
    May 2017
    Of course:
    Hitachi Seiki 5NF-800-img_5439-jpg
    Hitachi Seiki 5NF-800-img_5440-jpg
  18. #38
    Dec 2009
    So you have no alarms in that series. Where does the machine stand currently. What can you move / not move?
    You must have an overload in that series as circled on your diagram. That is triggering the THAL alarm. One of them must not be functioning. Did you replace them all?
  19. #39
    May 2017
    Yes, I replace all of them! Now the oil motors is ok! I think the NC, numeric control doesn’t responde same commands. I think the outside command to the machine no work! I’m crazy with this! Help me!
  20. #40
    Dec 2009
    Do you still have the THAL Alarm?
