- Need Help!- VK45 - Seicos III - Tape RS232C
Good morning,
For the first time i have to execute a big program with my VK45.
I try to load to cnc, but the memory is not enought.
So i try to send it directly from pc, but i have some issue.
1 - I press TAPE on VK
2 - I press start on VK, and the machine start to listen the RS232C
3 - I start to send code from pc...
The machine start to work, but after some seconds appear :
[0601 ] RS232C error
Transmission format is erroneous
The transmission metod is XON/XOFF, i think that the previous owner make a cable with RTS/CTS bridged
Thank you
Enrico
Re: VK45 - Seicos III - Tape RS232C
How much memory do you have and how much do you need?
John
Hello, I help you to make this communication! Send me email or call 561-305-0544.
My e-mail address jeanluiz@yahoo.com.br
Good morning,
i have solved the problem !
The previous owner used a fiber optic cable to transmit, so he made bridges to only use TX and RX pin.
I built a cable with the hardware flow control pin and everything works.
The machine receives command lines up to buffer filling, and then "tells" the pc to stop sending data.
Enrico
- You may not post replies
- You may not edit your posts
Forum Rules
