- HELP !!!!!! HiCell 23II with Seicos Lambda 10L control system
I was setting a tool in place while it was in the turret it spun the live milling holder in place. I unclamped it set tool in setter as i should have done. But when i tried to return holder it would not seat. I am getting a 1437 Action Finish Abnormal alarm, and a 1437 Mil.Spi del Fixation Abnormal. Please help I'm new and this machines been down for a day because of me. I already look bad making a bonehead move.
Re: HELP !!!!!! HiCell 23II with Seicos Lambda 10L control system
Hello
what its telling you is that the milling shaft is not lining up with the milling holder, Is the live tool connected at this moment? Loose?
- You may not post replies
- You may not edit your posts
Forum Rules
