Time ago, I had the machine running, after a partner changed or moved the micon, well put the ATC in Maintenance Mode "FF" and moved the tool change arm, now I can not use the machine, because I can not Turn the spindle or make tool changes, when I have a code m03 the control is alarmed. Can help me reset or something to rework it again.
Is the ATC at it's home position?Time ago, I had the machine running, after a partner changed or moved the micon, well put the ATC in Maintenance Mode "FF" and moved the tool change arm, now I can not use the machine, because I can not Turn the spindle or make tool changes, when I have a code m03 the control is alarmed. Can help me reset or something to rework it again.
Sent from my SM-G930V using Tapatalk
