Need Help! VS50. How to enable DNC option or increase the memory size?
Results 1 to 2 of 2
Thread: VS50. How to enable DNC option or increase the memory size?
    Default VS50. How to enable DNC option or increase the memory size?
    is there any way i can enable the DNC option (it says that option not found) or at least increase the memory capacity for my Hitachi Seiki VS50? Because it is a real pain to have a capacity of 50kb. Also does anyone know how to change some of the parameters? For example, i have an N9024 00000010 and i want it to have all zeros but when i hit enter, it asks me if im sure to change the parameter and i cannot find the button YES -lol-
    Thanks in advance
    Member shas595's Avatar
    Dec 2009
    Default Re: VS50. How to enable DNC option or increase the memory size?
    Hello
    for the parameter change - you have to hit Y when it asks "are you sure?" - but it also may be locked out since its the 9000 series.
    Depending on the control of your VS its either an option parameter or you can only expand the memory via SRAM - there is a procedure outlining this process w/ hardware installation procedures and upgrade instructions - you can go up to
    PM me for more details on this
    John
