- Direct Tapping on VK45
i' have a problem with my VK45 with seicos control.
I've to do a direct tapping with G841 code, and it's work fine, but sometimes
when a tapping is finished the machine doesn't go to the next hole.
When it happens i see on frequol's display a number of 1 / 2 instead of 0 ( i think that the machine wait the spindle stop signal before move to the next hole )
There is a parameter to decrease sensitivity of the frequol, or a parameter to bypass this error on seicos control?
Thank you
Re: Direct Tapping on VK45
Assuming it is a Seicos III with an FR-SF Freqrol - there is a method to adjust the direct tap drive built into the machine.
Make this quick program:
G21;
G91 G28 Z0;
S2000;
G841 S2000 F2000 Z-200. L10;
G80;
G20;
M30;
Run the program in single block. When you get to the G841 line - Press FR/BK -> Press F4(SYSTEM) -> Select 2.DIAGNOSE -> Select 3.RELEVANT TO SERVO
and check the spindle droop amount.
Is it zero ? (Number 01 - value under S)
Let me know
john
Thank you John
No.. the value oscillates between -105 and -126 ( when the spindle is stopped )
Enrico
Best is 0, good is +/- 15, and anything more is not good. Hold the AUX button and press H - this will take you to the Servo Adjust Screen. Adjust the loop gain at the bottom, press return and repeat the steps from before and get it as close to 0 as possible
John
I changed the value from 60 to 250 , and in diagnosis screen i read a medium value of -15, but is normal such a big difference in the values that I changed?
Enrico
Enrico
It is ok - as the drives get older they need tuning up. Try that out now and see if your program stops
John
It seems to work.....
Thank you John
Enrico
Glad to hear it - let me know if there is anything else I can help with
John
- You may not post replies
- You may not edit your posts
Forum Rules
