- Monitor problem
Monitor problem
how can I CHECK WHY THE MONITOR IS NOT WORKING ON HC 400 WAS WORKING AND THE QUIT , ALSO I HAVE PROBLEMS DOING THE TOOL CHANGE AND PALLET CHANGE CAN YOU HELP WITH THAT THANKS
Re: Checking servo's for voltage,, hitachi seiki hc 400
I have my monitor shut of it was working fine and quit ,what do i NEED TO CHECK TO MAKE IT WORK AGAIN THANKS
Re: Monitor problem
Hello, need a little more information. What is the machine control? Is the control still functioning? Can you still jog the machine/run spindle?
John
- Monitor problem
- You may not post replies
- You may not edit your posts
Forum Rules
