- hicell ca 23 24volt power alarm fixed now its one more proplem need help
hi again
my chuck clamp doesent work cant close and open it
and the same with the turret tools cant clamp it or unclamp
the hydraulic oil pumps works.
does anyone knowes whats can be wrong
machine is hicell ca23
regards Hans
Re: hicell ca 23 24volt power alarm fixed now its one more proplem need help
Hans,
does this Hicell have the Seicos III controller? Best place to start is to see if the signals from the button and foot-switch are making it to the control. Let me know the control and I can tell you where to look
John
Hi John
Its seicos lll
Regards Hans
Hans,
if the machine is in standby, check out the solenoids for the clamp/unclamp for the chuck and tool block. They often get fried and no longer respond. You should see a light corresponding to the current state of the chuck and tool (both should be clamped at this point, I assume)
- You may not post replies
- You may not edit your posts
Forum Rules
