Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 02-17-2010, 01:30 PM
teamus is on a distinguished road
Question need help on G76
On the second G76 line, how is the X dimension calculated for for a tapered thread? Both id and od?
Thank you
Old 02-17-2010, 04:51 PM
CNCRim's Avatar
Hope it help
Old 02-17-2010, 06:37 PM
Thanks, but I'm looking for how the X or U dimension is calculated. It is supposed to be the diameter at the end of the stroke but being on a 1 degree 47 minute angle, how do you figure the X diameter to put in the second line??
Old 02-18-2010, 12:04 AM
CNCRim's Avatar
A trig calcualtor will come handy. Most job will only require right triangle formular, for for info http://faculty.matcmadison.edu/kmiru...gonometry.html
Ok take 1deg 47minute for example, and assum the lenght of the program for the thread is .56" and .56" is on close side of the degree, so look at your right angle it's Tangent formular(Opposite/adjecent = tan), so just plug the number in the calculator Tan 1deg47minute x .56" . That will give you the value for X, Note: that's is only for one side, also Z start point need to take into consideration of the calculation legth.
Example,
G0X.6Z.1(take this length into calculation)
G76 P011560 R0.2 ;
G76 U.12 Z−.46 R.087 P6.0 Q.35 F4.0(Z is shorter .1)
