Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 01-14-2010, 07:40 AM
TitaniumCannons is on a distinguished road
Whats better a Microkinetics CNC 1340 or retro fit the hardinge DV59 for Cannons
Hi Again you all
This is my delima what i need the lathe for is to turn brass & titanium for scale cannons i have a DV59 hardinge lathe with a split bed. One thought is to convert it to cnc with mach 3 thk rail & ball screws for a x travel of 30 or so inches and 12 on the X. I fiqured it may run between 2-3 k.
Or i have an opportunity to get a Microkinetics CNC 1340 lathe thats made in 2007 and has less than 2 hr on it reason why the low hours are because he is having the parts made elsewhere. he has around 13k in it and wants 6-8k is this a good deal.
I had look in this forum for info on this lathe and its about 50/50 or so one guy here that makes paintball parts has one and is happy with it and another has problems with the tool path and usb port.
Below are some images of the work that will be done on it. Again Thanks for any input information you may beable to advise thanks Austin
Old 01-15-2010, 02:40 PM
Runner4404spd is on a distinguished road
the microkinetics deal depends on the accessories. i saw his ebay ad and really you can get a brand new microkinetics lathe with threading for $500 more than he's asking. if the micro sold for 3000-4000, then that might be a better deal. ultimately if your selling these you may want to drop a few quotes out there. you'd be surprised what you can get parts made from these days. you can buy alot of cannons for $8500
Old 01-15-2010, 03:28 PM
Larken is on a distinguished road
Are you sure you want to put linear rails on a lathe ? They have to be super rigid to get a good cut. The Dovetail ways and V type saddle is the best. You can an auto-oiler on the ways.
BTW, Nice cannons.
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
Old 01-15-2010, 06:11 PM
Hardinge lathe
On my hardinge it has the split bed its an older type i which i had the dovetail one i have a piece of cast iron that's like 4 foot log by 18" by 2" thick and weighs a ton too i was going to face it on one side and mill the bed out so it would seat nicely on the lathe bed and have several bolts holding it down in the t slot. That would be after it was trued up for the rails but all this seems like way to much work. that's if i had the time. Thanks Austin
BTW, Nice cannons.
Old 01-15-2010, 06:25 PM
Micro lathe
Hi Their
I had tried to get Quotes last year when i had to make 40 of those med size brass mortars and the best one was 30 bucks each in quanities of 100 but the problem is i have like 10 diffrent cannons i had made for customers and i had sold them at a good price and people like them there are one that other makers that want twice as much for but not as good. And i figure this CNC is low enough not the 8k but maybe 5-6k and since he's only 100 miles from me and i had spoken to him and i'm going to look at it in the morning and i think he said it does have the threading attachment and other tooling and accessories to I'll know more tomorrow. And this will be good for the Bersa 380 Titanium firing pins i had made one for mine and it works great. And i had some orders for 1/2 scale and 1/3 scale howitzer cannon and this bed is fairly long so. It would be great if i could get this made for less but no one would thanks Again Austin
Old 02-12-2010, 08:01 PM
Thumbs down What A BIG Mistake I hade made MicroKinetics
Well I now wish i hade retrofitted the Hardinge lathe. against fellow recomendations i went ahead and purched a used microkinetics CNC 1340 lathe and it has been nothing but problems. I sure i will have to re retro fit it with another controler and encoder unles i pay the 10% of 13k for the warenty transfer. I had read only good about this machine so i thought it was good but after getting it its been nothing but problems 1 was the polarity which was resolved on the x axis but also a threading issue in which after i spent $150 for which was cheap because i had posted a banner on my website but it still wasn't worth it because there only support is that i send the encoder back at a small fee. But with the issues so far i will not pay the $1,300.00 for the transfer of the waranty because from what i see so far there will only be more & more issues. I'd be better off re retrofitting this with a new controler so if you all have any ideas please let me know I'd like to run Mach 3 there software just doesn't work it times out if you know where to buy a kit let me know i should beable to use the drive i have i'll give you all the other stuff like the driverack subsystem its useless to me
Thanks for any info Austin
Old 02-13-2010, 11:20 AM
Is that a stepper drive or servo. What type of drives are in it.
Also how many lines is the spindle encoder ?
Is the spindle variable speed ?
Larry K
Old 02-15-2010, 10:46 AM
the microkinetics lathes are stepper drive. also the spindle speeds are set with the gear box.
Old 02-15-2010, 11:55 AM
Image's of the encoder MIcroKinetics 1340 Lathe
Hi Thanks for the info.
I had meant to get back to Larken earlier but I had been busy trying to get the lathe working & set up but it’s really useless.
I had tried their threading wizard in the Turn master Pro Program But in the demo version your unable to use it. I had acquired about the spindle being control in the program and what I was lead it was but it’s not like it shows in Turn Master program I had understood that the spindle speed wasn’t unless you purchases the VFD for $1400. I could always install a solenoid actuator and have it pluged into the back of the control box so when the M03 command is entered it will activate the hand switch and turn it off also when you do the tool change. And the same with the reverse if I ever needed it with the coolant outlet but that’s it there are only 2 plug on mine but it shows four on the current models of the 400 driverack. As far as the encoder I don’t know how many lines it has 4 wires indx & channel A on the controller. And that is useless because it doesn’t work. I had called them Tech Support and had entered the M25 #THREADINGSUB as he said and still the program stops waiting for the encoder and times out below is the g-code that their Wizard generates for a 3/8 24 thread That’s without the G25 #THREADSUB Command he told me to enter. However he said for a fee I could send the encoder & Controller back to get it fixed. But if I had paid for the transfer of the warranty of $1,300 which is 10% of the original purchases price 2 and a half years ago I’m sure I could get it fixed but I already have close to 7k into this So my only option is to spend more money on a new controller for the steppers and get rid of their control box and use Mach 3 I guess
After going on 2+ weeks I had been able to get 1 of their cnc programs to work after the x axis polarity problem was resolved But I have been unable to import any of the DXF files from my cad program into their Turn Master software thru the import tool.
I had done research on the company and all the reviews here were good exepct for some of the x axis operating faulty and the loose bolt problems which were clearly the case on this lathe close to all of them on the slide were loose along with wires on the federate override dial.
I had thought that since the machine was only a few years old and was barely used it would at least perform a little. I would have been better off retrofitting the Hardinge lathe This is all so discouraging. If any of you have a Basic g code program for threading on this machine please post it and I’ll try it
M25 #THREADINGSUB
#THREADINGSUB
G91 /Use Relative Offsets
/ External 24.0038 TPI Threading Command
G33 X-0.0248 Z2 I0.003 K0.04166
M17 /Return
Old 07-04-2010, 04:19 PM
shep640 is on a distinguished road
I have a 1236 lathe and I feel your pain. Did you ever get it up and running? It took me about 8 monthe to finally work out the major problems and I have been using it without to many problems lately. If I can help you I would be glad to go through the steps I have taken.
  #11   Ban this user!
Old 07-05-2010, 12:41 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Do you still have the Hardinge?
If so, you can make a dandy CNC by copying what Accuslide used to make. Essentially, it is a 2 axis gang tooling set up that clamps to the v-ways. There's a little bit of data about it on my web site:
http://www.cnccookbook.com/CCLatheCNCGangSlide.html
They're very slick, and I know several shops still running them that swear by them. You may be able to get one used on eBay.
Failing that, they sure don't look that hard to build.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Help With Microkinetics 1340 cnc lathe saberforge General Metal Working Machines 2 02-20-2011 01:33 PM
Smithy 1340 Cnc TPMX Smithy 1 12-07-2009 04:04 AM
servo setup whats need and whats do i need to know jhtmfg Benchtop Machines 0 10-09-2009 06:29 PM
Need Help!- Hardinge DV59 CNC retrofit Captdave Hardinge Lathes 0 07-31-2008 08:05 AM
Smithy Granite 1340 for sale Ken_Shea Smithy 0 07-28-2008 08:55 PM
