Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 12-29-2009, 08:37 PM
JP Hardinge is on a distinguished road
Any Ideas on Manual Indexing a Hardinge CHNC Turret?
I have an early Hardinge CHNC that's been coverted to a Fagor 8025 TG control with new servo motors on the X&Z. I've been able to modify the 3 phase 230v input current and run the machine on my 120v single phase off grid system.
I'm planning to use 8 position Omni-turn gang tool blocks with it.
The Turret has been gutted pretty good as who ever did the Fagor, made it to work in a fixed position with no turret indexing.
Does anyone know how to make this turret manually indexable? I pulled one of the covers and found one of the clippard valves gone, and the airline cut.
I think I may just unbolt the turret and swap it around 180 drgs when needed. If I drilled and tapped 2 more mounting holes I could get the other 2 positions. A pain I know, but at least I could get more mounting options.
It would be nice to be able to wire up a switch box and get to lift to where I could turn it, then have it drop back in place.
ID:	96348   Click image for larger version
ID:	96349   Click image for larger version
ID:	96350   Click image for larger version
Old 01-04-2010, 12:03 AM
kcho is on a distinguished road
Turret
Ok look the sticker in the cnc back and tell me the model or when the cnc poweron, it´s an 8025TG or TG-I?.
If you want to uses it automatically you have to program a PLC and you can change the stations using the T command for tool change.
Let me now and I can help you.
Carlos Cabrera
Old 01-04-2010, 11:03 AM
Carlos,
My Fagor is a TG.
Problem is my turret is disabled. I found I have to locate some missing parts to get it to index even manually.
Do you know how I could use my Fagor to turn the collet closer on and off to adjust it?
I need to be able to toggle between M codes so I can see it close and open, and be able to set the closing pressure.
Probably simple, but I'm just starting to learn this Fagor. I've got it peck drilling really well.
Thanks-
Colchester Tornado 200 Fanuc OT Control - Turret indexing problem JohnWD Fanuc 10 12-29-2009 09:10 AM
Nakamura tw-10 turret indexing maximusek CNC Machining Centers 0 09-03-2009 01:05 PM
Turret Indexing Problem SL4 ndp Machine Problems, Solutions , Wireless DNC, serial port 11 06-30-2009 10:39 AM
Newbie- Hardinge T51 turret problem gtsraven Fanuc 4 04-13-2009 06:52 AM
Turret Not Indexing rajesh_1355 Fanuc 0 02-24-2007 11:25 AM
