Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 11-23-2009, 03:00 PM
*Registered User*
lyfordln is on a distinguished road
Hardinge HNC with Mach 3
I am finally starting on my replacement of an Allen Bradley Control with a Mach 3 system and servo drives. The machine is a Hardinge HNC with 8 station turret. I want to use my 2HP drive motor
Here is my list. Please comment and suggest anything that will reduce cost, increase reliablity, or make it easier.
Mach 3 Software
Geck 320Z drives
CNC4PC C23 BOB
Smooth Stepper Warp9
VFD Automation Direct GS2-25P0 (5 HP) Will upgrade current 2HP Motor later
Power Supply Keling KL-8215
Index Pulse Card CNC4PC
MPG CNC4PC
X/Z motors Keling KL34-180-90
Thank you in advance for any help you all can give.
Old 11-23-2009, 03:18 PM
jalessi's Avatar
jalessi is on a distinguished road
Question
Why not use the C25 it would be a lot less money?
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 11-24-2009, 11:52 AM
*Registered User*
Hardinge HNC Rebuild
Having only a small amount of electrical/electronic knowledge, I thought it might be smarter to use a opto-isolated board.
All comments and suggestions are very welcome.
Old 11-24-2009, 12:47 PM
jalessi's Avatar
Post
Lyfordln,
Since the Gecko's already have built in opto isolation, I would not waste the money.
Jeff...
Tags
hardinge, hnc, lathe retrofit
Mach 2 Mach 3 Post Processor IntarisiaQ4 Australia, New Zealand Club house 0 10-17-2009 05:50 PM
Hardinge HNC Artitus Hardinge Lathes 0 06-12-2009 04:29 AM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Moving to mach 3 need exact mach 2 screen carlnpa Mach Software (ArtSoft software) 2 12-11-2005 03:00 PM
will mach 2 or mach 3 work for 4 axis cnc? Runner4404spd Mach Mill 3 10-05-2005 11:44 AM
