Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 10-27-2009, 07:31 PM
nakatome is on a distinguished road
chnc I turret up problem needs a clue
having problem with turret up for turret to index turret trys to go up but slow
or no pressor a little help up with allen key, then it indexes to next station . changed stop valve and quad/orings in valve block , changed turret up valve, no change hear air blowing when turret trys to go up , need a clue
Old 10-27-2009, 11:07 PM
Nawrocki4Life's Avatar
Nawrocki4Life is on a distinguished road
On CHNC's there are a good number of seals/ o-rings that are in the many parts of the turret. Chances some of these, or possibly just one, is allowing air to flow to a part of the machine it shouldn't. I work on Harding equipment all the time. when these seals leak, the turret either raises and indexes but never seats, delayed/slower indexing times, and louder air leaks. Im a service tech for a midwest distributor of Hardinge equipment. Hardinge has a sales seal kit for CHNC's you should find your dealer around u and get one of these on order. Then pull out your part list and you can figure out where they go and how the turret is assembled.
Old 11-03-2009, 04:54 AM
duenow is on a distinguished road
Correct, after 12 yrs on my bought new CHNCI that started, a new turret o-ring kit fixed it. Lots of seals & rings in that kit.
HAAS SL-20 TURRET PROBLEM HELP allmotormatt Haas Lathes 11 01-20-2011 12:47 AM
Hardgine CHNC II turret problems CatesMetal Bridgeport and Hardinge Mills 5 08-28-2009 08:14 PM
Need Help!- CHNC II GN10 control Initial start up problem LeftCoastCNC Hardinge Lathes 1 07-13-2009 11:00 PM
Hardinge CHNC turret woes Karl_T CamSoft Products 7 12-19-2006 04:54 PM
SL 10 turret problem PBMW Haas Mills 1 08-15-2006 09:51 PM
