Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 08-06-2009, 06:48 PM
Jeff_Mezzo is on a distinguished road
Hardinge Conquest Twin Turn 65
Been having troubles with the main spindle collets sticking when trying to feed material out to a stock stop. When you take the collet out there are burn marks on the angles portion of the collet. I clean the collet up and it works fine for about 10 minutes and it will start doing it again. I f you slap some grease in around the collet it might work good for a few hours tops. Anyone have any suggestions?
Old 08-09-2009, 11:24 AM
g-codeguy is on a distinguished road
Never heard of such a thing. Don't see how it could be possible unless the collet is turning separately from the spindle. This should be impossible because the spindle has a pin that must fit in the collet's keyway in order to be tightened. You must be missing the pin or it has been buggered up to the point it is no longer long enough to fit in the keyway.
EDIT: I assumed you were running 16C or 20C collets. Not familiar with that model. We are running 6 Hardinge barfeeds. Got the first one about 20 years ago. None are Twin spindles, tho. Did you order it with different collets? Or does it come with different collets than the two I mentioned? We have a Nakamura TW20 that uses B42 collets. There is no keyway on these. However, we have never experienced the problem you describe. No keyway sure makes it hard to automatically load a new bar of hex material.
Old 08-10-2009, 04:39 PM
the burn marks dont appear to be from the collet spinning in the main spindle, looks like from colloet moving in and out. They key ways are in tact.
Old 08-12-2009, 10:24 AM
duenow is on a distinguished road
Grind a small X over the burn marks with a thin cutoff wheel , then use lipstick. I've been doing this for 35 years for all my screw machines.
M-code for Hardinge Conquest 42 b23 Fanuc 4 02-18-2009 09:53 AM
hardinge conquest 51 problem bassmastrbw96 Hardinge Lathes 1 09-04-2008 09:39 PM
Hardinge Conquest 42 cncdiag Fanuc 1 05-20-2008 08:06 PM
Hardinge Conquest won't home? Jim Wilson General Metal Working Machines 1 11-02-2007 12:44 AM
Training on Hardinge conquest t-51 mailloux General Metalwork Discussion 0 09-20-2007 03:58 PM
