Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 07-24-2009, 03:54 PM
Michael82 is on a distinguished road
1043 recirculation pressure fault
I have a Hardinge cobra 65. Every time the machine is turned on the machine after getting it ready to start it throws this alarm 1043 Recirculation Pressure Fault .The reset button will not clear it the cancel button with the reset button at the same time does not work ,nothing will clear this alarm. Can anyone help out ????????
Old 10-27-2009, 11:59 PM
Nawrocki4Life's Avatar
Nawrocki4Life is on a distinguished road
hydrolic system.
yes on that machine there is a smaller motor/pump on the hydrolic tank that is the same as the coolant pump. either the overload is triped on the relay in the elec. panel for that pump or the pump itself is bad. on the hydrolic unit in the back of the machine, there is the main motor/pump (the big one) and a smaller one to the left of it. to remove the smaller one the whole unit needs to be unbolted from the floor panel and then swong out away from the machine. *the pressure switch itself could be bad but that usually isnt the problem*
Last edited by Nawrocki4Life; 10-28-2009 at 12:02 AM. Reason: added the "*" statement
Need Help!- Low Lube/Oil Pressure VF2 jstucken Haas Mills 10 10-27-2010 09:17 PM
hold pressure on????? fsa Mechanical Calculations/Engineering Design 0 08-14-2008 04:15 PM
Pressure regulator for oil Smackre Mechanical Calculations/Engineering Design 4 06-27-2008 01:21 PM
Melt Pressure plasticpeter Moldmaking 4 03-27-2008 05:45 PM
TSC pressure alarm (151) crayner Haas Mills 1 11-15-2005 11:45 PM
