Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 07-20-2009, 08:06 PM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Newall C80 readout on Hardinge HC Chucker Lathe
Here are a few pictures of the installation of a Newall C80 display with Spherosyn Scale and associated reader head on my Hardinge HC Chucker.
I only need the A/C adpater yet to complete the project. I ordered one today and hopefully it will be here by the end of the week.
Just thought I would share.
John
ID:	84719   Click image for larger version
ID:	84720   Click image for larger version
ID:	84721   Click image for larger version
ID:	84723   Click image for larger version
ID:	84724   Click image for larger version
ID:	84725   Click image for larger version
ID:	84727   Click image for larger version
ID:	84728   Click image for larger version
ID:	84729   Click image for larger version
Old 05-07-2010, 05:52 PM
Newall Microsyn Scale and Reader Head Installation
Here are a few pictures of my installation on the Newall Microsyn Scale and reader head for the cross slide on my Hardinge HC Chucker.
I was able to use the dowel pin that held the mechanical stop to attach the scale support bracket. Just made a little adapter bushing and put a slit in it so that it would compress when the bracket nut was tightened.
I also made an aluminum spacer bracket for the Microsyn Scale that has 2 each countersunk holes with 1/4 X 20 SHCS that screw into a .75 X .75 X .25 thick 1/4 X 20 threaded block that fits into TEE SLOT that was originally used for the Manual Stop. You can see the original mechanical TEE SLOT brackets that were OEM on the Hardinge HC Chucker. I also drilled and tapped 2 each 8/32 holes for mounting the Microsyn Scale to the aluminum spacer bracket.
The nice thing about this installation is not one hole had to be drilled into the original casting to accomplish this retrofit.
John
ID:	106645   Click image for larger version
ID:	106646   Click image for larger version
ID:	106647   Click image for larger version
2007 HAAS TM-1P OneCNC XR4 Mill Pro. Shopbot PRT running Mach3, 2010 Screen Set, Super PID and PMDX Electronics. Check out my Gallery on: http://www.helicopterjohn.com/
Need Help!- Looking For A Digital Readout For Mill Or Lathe. "USED" Fun Police Want To Buy...Need help! 2 01-21-2009 01:22 AM
Tool Room Lathe Chucker (HPCL) HAILINHAAS Haas Lathes 24 12-22-2008 12:38 PM
Scales for a Newall DRO damianks Calibration & Measurement 0 06-16-2008 09:04 PM
Hardinge Chucker Manual leeputman General Metal Working Machines 1 05-18-2007 10:44 AM
Hardinge Chucker With Upgrade Tech Cnc MILLMANM Bridgeport and Hardinge Mills 2 01-20-2005 11:45 AM
