Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 06-28-2009, 03:10 AM
LeftCoastCNC is on a distinguished road
CHNC II GN10 control Initial start up problem
Hello all, I am hoping someone can get me headed in the right direction here.
Short Version:
After sitting for two years with no power, on initial power up the CRT displays:
FS10TF 1315H
ROM TEST: END
RAM TEST:
And will never go past this. My guess is that I lost the memory batteries while it was sitting. Where do I go from here?
Long Version
I purchased a CHNC II for a hobby machine two years ago. As most of my hobbies, it was put on the back burner and has been sitting with no power to it. I read a couple weeks ago, that the memory is kept alive by batteries that should be changed once a year. OOPS! I tried firing it up tonight (so I could change the batteries under power) when I ran into the above problem.
It never passes that screen... I finally powered off after 5 minutes and tried again a few minutes later with the same result.
Is this a sign of the batteries having died and loosing everything? If so how do I start the long process of rebuilding it?
Or is it something else?
Any comments or suggestions would be much appreciated. I doubt that it matters for this problem, but the machine has been upgraded to AC Axis Drives.
Thanks in advance,
Kris
Old 07-13-2009, 11:00 PM
Has anybody had their memory batteries die? ...In their CHNC, not personally
Arrow 750 Failed to start when I Push start Bottom in fornt of control ! mte.jalal Cincinnati CNC 4 01-06-2009 11:20 AM
Sodick EDM machine Model A7C with MARK XI Control - Start up problem rajappa EDM Machines 9 07-20-2008 11:08 PM
spindle start problem endgrainguy General Electronics Discussion 3 05-03-2008 10:04 AM
Help - Spindle Will Not Start from NC Control CSE Bridgeport and Hardinge Mills 7 05-24-2006 12:56 PM
Initial site viewing problem Al_The_Man Forum Questions or Problems 2 08-17-2004 06:23 PM
