Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 06-18-2009, 11:08 AM
CatesMetal is on a distinguished road
Need Help- Hardinge CHNC II
I'm having some problems with my Hardinge CHNC II. Maybe someone has some suggestions for things to check or troubleshoot so I can this machine back up and running. Here's what's going on:
When the machine is turned on, and I try to zero return, the Z axis homes out fine but X overtravels- it never slows down like it it sensing home position. So far I've tested the relays that are on the left side of the cross slide at the back. There are 3 of them stacked together and they are all 24 volt. All of them read 24 volts and when I depress each one, they all zeroed out, so I am assuming these are good. I've been on the phone with Hardinge technicians and made no progress.
ANY suggestions are appreciated. Thanks-
Old 06-19-2009, 09:35 PM
Runner4404spd is on a distinguished road
did you check the operation of those switches at the cabinet or at the switch? if at the switch i suggest checking in the cabinet make sure you don't have a broken wire.
Old 06-21-2009, 03:46 PM
88incher is on a distinguished road
Silly thought, Check for swarf on the X home prox. switch. I quite often had to clear steel swarf off our Z axis one as they are magnetic.
James
Old 06-22-2009, 10:20 AM
I checked at the switches, so I will check at the cabinet also.
And do you know where the magnet is located? Someone else mentioned it to me, but I'm not familiar with where it's at.
Thanks for the suggestions!
Old 06-22-2009, 11:54 AM
yours_prabhat is on a distinguished road
Just re load the parameter from IPL mode If you have back up of machine.If you can successfully re load the parameter once in machine to clear all memory your problem will be resolved If still you have any problem you can communicate me on prabhatmishra@mail.com or on +91-9430737981
Regards
Prabhat Mishra
Need Help!- HARDINGE CHNC II MadMan5000 Machine Problems, Solutions , Wireless DNC, serial port 0 04-15-2009 01:33 PM
HARDINGE CHNC II MadMan5000 Machine Problems, Solutions , Wireless DNC, serial port 1 02-21-2009 12:00 PM
Hardinge CHNC N4NV General Metal Working Machines 0 01-07-2008 09:58 PM
Hardinge CHNC ? KevinCram CNCzone Club House 0 10-19-2007 09:27 PM
Hardinge CHNC retrofit Karl_T CamSoft Products 0 09-09-2004 09:49 PM
