| Hardinge Lathes Discuss Hardinge Lathes here. |
#13
| I completely cleaned and detoxed my Hardinge chucker and first model Hardinge CHNC, then run Ballistol soluable oil and water mix. These are oil only machines, but I place a piece of clear plastic bout' 6 mil, with a hole cut for the spindle as a splash shield, then put the splash guard back on over it. It keeps all the coolant off and away from the bearing. Simple fix. My CHNC has had a Fagor 8025TG retrofit with new servo motors. The turret indexing was hopeless, and to costly to fix (they never work well) so I set it up as a gang tool fixed position. The worn air O-rings caused rotational flexing in the fixed position. I drilled and tapped the turret plate with 5/16-24 set screws on 4 positions and it locked it down solid from .004 flex to much less than .0005. ![]() ![]() ![]() ![]() Also these machines blead air like crazy, so be prepared for long compressor cycle running times. I disconnected my Vari-grip collet closer from the machine air supply, and connect air directly to it only when I need to open and close it. Otherwise I could not afford to run the compressor for leakage as my shop is off grid. All of this is limiting obviously, but for a home business shop it still is CNC and a very productive accurate machine for my needs. I paid $2000 for mine. Last edited by JP Hardinge; 04-22-2010 at 09:41 AM. |
#14
| $2000 for a really accurate and solid gang lathe is not bad. I agree, switch the turret to a gang configuration. Faster tool changes anyway! Cheers, BW
__________________ Try G-Wizard Machinist's Calculator for free: http://www.cnccookbook.com/CCGWizard.html |
#15
| I don't know about all this doom & gloom on the CHNC's. I bought in 1992 a new CHNC I & it's still running 8 hours a day now & will still hold .0003. Oil only since day 1. The thing about oil is you put it in once & only add some unlike water crap you have to change out & skim the lube oil. In 18 years I have replaced a few air valves & new O-Rings on the turret (1 time). you can still get any parts you need. I have never had to adjust the gibs (mostly because it's all covered with oil). I run a lot of SS with a 16 finish (try that with water crap). Yes it does use air, I take 3/4 shank WNMG tooling & mill the shanks down to 1/2". |
| HARDINGE CHNC II | MadMan5000 | Machine Problems, Solutions , Wireless DNC, serial port | 1 | 02-21-2009 11:00 AM |
| Need Help!- Part for Hardinge CHNC II | CatesMetal | Want To Buy...Need help! | 0 | 08-18-2008 11:11 AM |
| Hardinge CHNC | N4NV | General Metal Working Machines | 0 | 01-07-2008 08:58 PM |
| Hardinge CHNC ? | KevinCram | CNCzone Club House | 0 | 10-19-2007 08:27 PM |
| Hardinge CHNC Retrofit | cbucner | Vertical Mill, Lathe Project Log | 6 | 12-29-2006 08:57 PM |
