Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
  #13   Ban this user!
Old 09-16-2010, 09:36 AM
Sabrina_B is on a distinguished road
I wish i could call Hardinge. I have tried several times, but always get Morris South and they can't seem to help. I am about to pull my hair out! No support these days.
  #14   Ban this user!
Old 09-16-2010, 09:42 AM
LMartin is on a distinguished road
I did a lot through email so this was one of the contact people. David.Heifferon@hardinge.com
  #15   Ban this user!
Old 09-16-2010, 10:03 AM
Just called hardinge back again. they don't support this machine anymore bc of age. If you could remember when you had this problem was it resting parameter 124. Someone did tell me i have have to reset parameter 124 to 0 if it was over 40
  #16   Ban this user!
Old 09-16-2010, 10:36 AM
Great!!!!! he called me immediately! He gave us a list of stuff to check. Sounds promising. You have no idea how much you helped. I haven't been able to get any support. The direct contact info. was very helpful. You must be very organized to still have his contact info. Thanks so so so so much. Keep you posted.
  #17   Ban this user!
Old 09-16-2010, 12:43 PM
I never got the machine up and running in production, I was able to run it through a cycle once i put in a simple program but would not continue to run. And then I put in the wrong viscosity hydraulic oil. I just got new oil a couple of weeks ago so I can drain and try it again or the pump is shot. Sorry I do not think I can be of additonal help.
I know thye did not support the machine but some of the old guys would suggest different things to try. I was close but no cigar.
  #18   Ban this user!
Old 09-16-2010, 01:39 PM
well actually you may be of help one last time and i will quit bothering you. You said something about the hydraulic oil. My boss didn't order any special he went to the tractor supply and bought hydraulic tractor oil could that be out problem the whole time ?
  #19   Ban this user!
Old 09-17-2010, 09:42 AM
the heater we have now keeps shutting off. What size did you get? Ours is a 46 watt. oh you replaced fuses too didn't you.Sorry to keep bothering you. This is the last time i promise.
Need info on Hardinge Superslant SB-3GN CNC Turning Center Crashmaster General Metal Working Machines 7 09-09-2010 09:26 AM
m31 on hardinge superslant 6t control winton Hardinge Lathes 2 05-02-2009 10:51 AM
Hardinge Superslant GN-6 RS232 Comm NEC Hardinge Lathes 3 11-28-2008 12:30 AM
hardinge superslant retrofit fcycles General Metal Working Machines 0 02-14-2008 09:15 PM
