| Hardinge Lathes Discuss Hardinge Lathes here. |
| loose belt or dirty sensor. remove the screw on top of the machine to allow you to swing the control panel out. Once you have the control panel out of the way you will be looking at the spindle there is a flat plate towards the right side which covers your sensor. there are two rings on the spindle one is for rpm one is for orient gap should be around .005. It is probably a most likely the belt is too loose If teh sensor is not picking it up there is usually a disconnect alarm. |
am new to internal taper threads and am missing somthink |
| Tags |
| 1114, hardinge, main spindle, tt-65 |
| Adding 4th axis to Hardinge w/fanuc | BobM3 | Fanuc | 4 | 01-08-2012 01:15 AM |
| Need Help!- fanuc gn6tc hardinge | fcycles | Fanuc | 3 | 01-28-2009 04:27 PM |
| Hardinge Cobra42 w/ Fanuc 21-T | danohpsp | Fanuc | 0 | 12-01-2007 12:14 AM |
| G-Code Problem on my Fanuc Oi Hardinge Lathe | Josh-PTP | Fanuc | 11 | 07-10-2007 06:42 PM |
| Upgrading a 2000 Hardinge VMC1000 fanuc omd | sco999 | Bridgeport and Hardinge Mills | 2 | 04-14-2007 03:22 PM |
