Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 12-27-2008, 10:06 PM
Billet Sean's Avatar
Billet Sean is on a distinguished road
Hardinge CHNC 4-16C Alarm 2009
Hi, I have a Hardinge CHNC 4-16C Lathe. I just powered it up today and everything works except the spindle. I'm getting an alarm 2009 "Spindle Brake On". Does anyone know how to turn the spindle brake off? I looked through all the manuals and they don't say anything. ANY help would be appreciated!
Sean
Old 12-27-2008, 10:48 PM
WGoyer is on a distinguished road
CHNC-4
Sean,
Some of these had the GE spindle drive and some had the Inland drive. If I remember correctly, there's a small interface board near the bottom of the right panel that measures the current flow in the DC motor's 90 volt brake. The brake must be energized to release and this board detects current flow in the windings of the brake and allows the spindle drive to start. You might want to find the wire numbers for the brake and see if there is 90V DC across the winding.
If that's all OK, check for a red alarm light on the GE spindle drive (if that's what you have).
Good luck,
Warren
Old 01-02-2009, 04:51 PM
rapidtraverse is on a distinguished road
Coolant tester
Have you tried the m-code for spindle break release? I think it is either M28 or M27.
Old 02-21-2009, 11:48 AM
cweiss is on a distinguished road
Not directly familiar with the CHNC4 but on CHNCI's and CHNCII's there is a small Clippard valve in the solenoid cabinet in front, by your feet where you would stand to operate the machine. I have replaced these before to solve that alarm. Good luck.
Old 03-18-2009, 06:16 PM
cncbasher is on a distinguished road
Theirs a small solidstate relay usualy on a seperate panel with a 30A block bridge rectifier next to it , most probably this relay is broken .
theirs also another in the same circuit , i think it's cr4 , i dont have the manual at hand so if it's still a problem let me know and i'll go diggin it out
Tags
2009, alarm, brake, hardinge
Hardinge CHNC conversion N4NV Vertical Mill, Lathe Project Log 292 06-04-2011 11:44 PM
hardinge chnc specs CASTLEVILLE General Metal Working Machines 3 04-20-2008 08:44 PM
Hardinge chnc retrofit cnc jheyliger General Metal Working Machines 0 02-28-2008 05:48 PM
Hardinge CHNC N4NV General Metal Working Machines 0 01-07-2008 09:58 PM
Hardinge CHNC ? KevinCram CNCzone Club House 0 10-19-2007 09:27 PM
