Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 11-07-2008, 03:23 PM
beege's Avatar
beege is on a distinguished road
Collet Open Button CHNCII+
The collet open button on my !!+ stopped working. I'd like to find out how:
To bypass/reroute to another button on the front panel - doable?
OR
Use the foot pedal option to attach a momentary contact switch.
Can't afford a new front panel yet.
Control is GN 10TF
Thanks!
Old 11-08-2008, 03:19 PM
Runner4404spd is on a distinguished road
take the panel off. i found that mine had the connector actually fall of the button and stop working. make sure there is a connection there first before trying to bypass.
Old 11-08-2008, 10:16 PM
beege's Avatar
Already had the panel off. All connections are secure. Next?
Old 11-10-2008, 10:19 AM
did you try jumpering the wires when the panel was off. maybe the switch is bad. other than you gotta start tracing wires. are you sure that the switch is bad and not the valve? the valve is located under the control panel in the middle access panel. i had to replace one of my solenoids when mine stopped working.
Old 11-10-2008, 12:08 PM
beege's Avatar
Thanks for trying to help. The back of the front panel is mostly a sealed circuit board, except for ribbon connectors in 4 plugs, and a few smaller connectors. I've managed to locate one of the pins on a 50 pin connector that supposedly connects to the collet open button, using the electrical diagrams.
I've also since discovered that the coolant "auto" button doesn't work either. Coolan "Off" and "On" work just fine.
I've unplugged all ribbon cables, cleaned them (didn't look dirty) and replaced them, to no effect.
Oh, and the Coolant "On" button isn't supposed to do anything with the door open, but it does...
Maybe another call into Hardinge is in order, but they haven't been too much help for this old machine.
Old 11-11-2008, 09:25 PM
DOA DOA is offline
DOA is on a distinguished road
solenoids
Sounds like the door switch may be defeated and I second the notion of checking the collet close soleniod. You may be able to use the "close" solenoid to check it's operation. Just switch solenoids. Can you hear the "close" solenoid working when you pess the pedal or button?
Old 11-12-2008, 09:09 AM
beege's Avatar
The collet opens with an MDI M21; Closes with the "Close" button. I don't believe its a valve issue, valve works fine under command... I'll check the door switch.
Old 01-07-2009, 12:11 AM
DOA DOA is offline
I recently had the same problem with my Conquest 42, except my problem was with the collet opening at the M30, M01 or reset during operating. The button was stuck ON. A little contact cleaner and I was back up.
I know it's been a while since you posted, but what did you find wrong?
Old 01-07-2009, 08:55 AM
beege's Avatar
Still a problem, not fixed. Don't know what's wrong, just want to put in a different switch somewhere...
Old 01-07-2009, 06:45 PM
DOA DOA is offline
Is the switch a membrane or a regular push button type?
  #11   Ban this user!
Old 01-08-2009, 07:17 AM
beege's Avatar
Current non-working switch is membrane. New panel would cost 3k,just want to replace with mechanical switch.
  #12   Ban this user!
Old 01-08-2009, 01:11 PM
DOA DOA is offline
My collet switch is a membrane too. The protective cover has been worn off and the film has opened up to where the button contacts are exposed. It's not much of a crack , but enough to let dirt and coolant from your finger to mess it up. I sprayed electrical contact cleaner into the membrane as I operated the switch...kinda tapping it, not pushing, and it started working again. You'll need an electrical diagram or call Hardinge to find the in/out puts of the switch and wire accordingly. If your coolant button isn't working too, I would be curios to see that it may share the same bus or strip on the board.
Good luck and post back what you did...
Use button to open file tmead Screen Layouts, Post Processors & Misc 5 10-30-2008 02:09 PM
What M Codes open/close your lathe collet ?????? nelZ General Metal Working Machines 2 09-05-2008 09:28 AM
Jogging with OEM button jeffrey001 DIY-CNC Router Table Machines 0 06-09-2008 05:29 AM
New Machine Build- EZ button? ericmattessich LinuxCNC (formerly EMC2) 15 04-29-2008 01:59 PM
so that is what that button does johnm Test Forum 0 03-26-2003 04:43 PM
