Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 10-18-2008, 10:43 AM
Don H is on a distinguished road
over travel in x at reference
It's a Hardinge Talent 8/52 with a Fanuc 0i-TC control
I was getting a servo alarm at start up that fixed itself with a reboot.......Now the X axis will not reference do to overtravel alarm 500.
Is this over travel the hard stop or is it a soft stop from the parameter settings?
What parameter sets the over travel in x?
Could my problem be that the hard stop and the soft stop are set too close together?
Or could the ard stop just have moved?
Thanks.
Old 10-18-2008, 10:54 AM
Al_The_Man's Avatar
If you are seeing a software overtravel, press 'Cancel' & 'P' on power up.
I believe this works on the i series, but have never really tried it.
Old 10-18-2008, 11:09 AM
Thanks for the reply Al...........
Start up is fine.
After start up the next task is to reference the machine. Handle jog -1.0 in x and -1.0 in z. Reference x first and I am getting an error for over travel. Not sure if the error differentuates between hard stop or soft?
Old 10-18-2008, 11:12 AM
Al_The_Man's Avatar
Hard overtravel switch can be seen by the I/O status on either the diagnostic, or ladder, if you have it enabled.
Guide reference GORILLA CNC Canadian Club House 1 10-15-2008 02:56 PM
5t reference problem bigalow 5T/5M 2 08-28-2008 11:51 PM
Good GD&T reference? pkelecy Mechanical Calculations/Engineering Design 2 11-04-2006 07:57 AM
Reference positions in DIY CNC davidp General CNC (Mill and Lathe) Control Software (NC) 4 05-23-2006 03:48 PM
Threading Reference jlv3901 General Metalwork Discussion 2 10-31-2005 03:49 PM
