Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 09-30-2008, 04:09 PM
YANKS_RINKS is on a distinguished road
bar feeding
Hi all
I have SV150 hardinge lathe. I want to bar feed hex bar using bar puller through the spindle. But I cannot stop the spindle at same position all the time for par puller to pull. I dont have the C axis capability. Is there any G code with which we can orient the spindle every time?
Old 09-30-2008, 04:38 PM
beege's Avatar
beege is on a distinguished road
On my Hardinge II+ its an M19 for spindle orient. Good luck ( a call to Hardinge might help, no charge...)
Old 09-30-2008, 08:52 PM
g-codeguy is on a distinguished road
As Beege said, M19 orientates the spindle per a value in a parameter. See if you can add an S-code to it. Use in the format M19S0300, M19S4511, etc. If his works, then you will be able to rotate the barstock to the exact desired position.
If the S-code doesn't work, either call Hardinge (easiest), or post back and I will see if I can locate the parameter, tho I bet I can't beat Beege in locating it.
Old 12-10-2008, 12:27 AM
JohnnyTurn is on a distinguished road
Da man
You can use G32 with a feedrate and a slow spindle speed of like 30-50 RPM to get the hex flats at 12:00 and 6:00.
S50M03
G4U1.0
G32W-.100F.032
M05
M1
(call puller)
etc.
Or, In my opinion, The best way. After cutting off, use the cut off tool to turn the flats off to the root of the hex about .093-.125 wide. Wallah, no more hex to grab, just a qualified diameter. And on a good day, the round you turned will be wiped out by the rough turning tool when you rough out the diameter.
Betcha wondering "why didn't I think of that?"
JohnnyTurn (turning excellence)
Drip Feeding widgitmaster Polls 26 01-28-2011 03:02 PM
mystery self feeding keen Mach Mill 17 02-25-2008 02:55 PM
drip feeding vtc-41 scottn Mazak, Mitsubishi, Mazatrol 1 11-08-2007 07:52 AM
Feeding On 3d file jamesr Surfcam 5 01-24-2007 04:56 PM
feeding rollers DrStein99 Linear and Rotary Motion 1 07-25-2006 10:44 PM
