Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 07-09-2008, 12:54 PM
TARIQ08 is on a distinguished road
Hardinge ot control
Hi there,
Can anyone help me, I reset the limiter on the Z axis of my hardinge conquest 42 machine(OT control) and my Z axis reference has to be reset, anyone knows the procedure.
Old 07-10-2008, 08:08 AM
g-codeguy is on a distinguished road
Sorry. Had to leave early yesterday plus I was having problems of my own. Talked to our maintenance guy this morning. He tells me Z home should be close. If you want it set perfect, then you will have to change the Z grid shift. Should be parameter 545. Paper I am looking at calls it "Drift shift Z".
Turret face is Z0. Spindle nose is Z0. I hope you got the handle working. I've never had to reset Z0 on an incremental encoder, but I think this will work. You are going to put a 1 inch jo block between the spindle nose and the turret face. This is why I hoped you had gotten the handle fixed.
Set the workshift to Z0. What does the W read in the ACTUAL POSITION (RELATIVE)? If not 1.0000, then you need to change the value in parameter 545. Don't know if it works the same way as setting a probe, but this is how I do it set the probe to read the correct geometry.
Multiply 25400 times the amount the turret is off. Add or subtract this value to the number in parameter 545. Only use the numbers to the left of the decimal point. Does the W read 1.0000, or is it off by more than before?
This is only a guess on my part. Hopefully it is set the same way as a probe. That way it will only take you a max of 2 trys to get it adjusted correctly.
EDIT: If this is wrong, then I hope that someone else will chime in with the correct method. You could always call Hardinge Brothers again. I am a programmer, not a maintenance man. Nor do I want to be one. I can do a few things, but best not to let the powers that be know. I already have more work than I know what to do with.
EDIT: This is assuming you could home the machine.
Old 07-11-2008, 09:28 AM
My Z axis is fixed with the help of hardinge, it was similar to what you were saying except it was parameter 509. Thank a lot for your help.
My X axis is also out of whacked, so we are trying to fix the problem, no luck yet.
Looking for hardinge vcm 1000 with fanuc 0-md control maintenance manual samu Bridgeport and Hardinge Mills 5 09-02-2008 09:36 AM
Hardinge esw03 Employment Opportunity 5 03-05-2008 08:41 PM
Hardinge With AnilamII control Kevin Taylor General CNC (Mill and Lathe) Control Software (NC) 0 06-19-2007 12:30 AM
hardinge ahc Runner4404spd General Metal Working Machines 0 04-11-2007 10:10 AM
feed control for hardinge TL eearango Mini Lathe 0 11-20-2006 03:15 PM
