Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 06-10-2008, 12:52 PM
NEC NEC is offline
NEC is on a distinguished road
Hardinge Superslant GN-6 RS232 Comm
Hi there,
I have a Hardinge Superslant GN-6, recently got mastercam and am using Cimco transfer software. Played with all the settings and using a 'Smart' cable was able to transfer off the lathe to the laptop without issues.
I can't seem to get it to read into the lathe though. Anyone have any hints on the proper CR/LF and other parameters I should be using?
Much appreciated, thanks
Dave
Old 11-19-2008, 08:38 PM
John Bunker is on a distinguished road
Hi Dave,
Sorry if this reply is late, I just read it today 11-19-08.
I also use Mastercam (X3) and CIMCO Edit (ver 5.12.06) to run my Conquest 42. I'm connected to the lathe RS-232 from my laptop PCMCIA port which uses a Quatech card and drivers.
My DNC settings in CIMCO are
PORT:
stop bit: 2
parity: even
baud rate: 9600
data bits: 7
TRANSMIT:
\10\13
All other DNC settings in CIMCO were left as default.
Old 11-19-2008, 11:44 PM
gm3211 is on a distinguished road
Dave,
When you attempt to read at the control, disconnect the cable and see if you get an alarm. This means that port is set correctly and it is trying to read in. If not, then something might be up with sending port or cable (smart switches).
Greg Mercurio -Shop Floor Automations
www.shopfloorautomations.com /619-461-4000
Old 11-28-2008, 01:30 AM
NEC NEC is offline
Hey thanks John and gm3211, I finally got it a while back there. My settings are very similar to those John had below, can't recall for sure off hand but it turned out to be the handshake transmit protocol. I ended up downloading another transfer protocol program, it worked so I took the same transmit protocol number (i.e. \10\13 or whatever) and used it in CIMCO edit.
Thanks again!
Need info on Hardinge Superslant SB-3GN CNC Turning Center Crashmaster General Metal Working Machines 7 09-09-2010 10:26 AM
hardinge superslant retrofit fcycles General Metal Working Machines 0 02-14-2008 10:15 PM
fusion 640m rs232 comm camcutter Mazak, Mitsubishi, Mazatrol 3 05-30-2007 12:23 PM
comm 1 is out help please dcrblazer Milltronics 0 04-16-2007 11:26 AM
