| Hardinge Lathes Discuss Hardinge Lathes here. |
| Polyturning...anyone done it? Has anyone got experience with polyturning capabilities on the Hardinge 42, 18T? or any other machine? I have a notion to experiment, but want to hear some things first. |
| That's some interesting turning processes, but it's more like horizontal hobbing. My machine is supposed to be capable of polyturning, but I don't have live tool capabilities. Does anybody know if polygon shapes be cut using the standard turret tooling? I guess I'll have to start experimenting. |
| First of all get off this "poly-turning" phrase. You are talking about a lathe with live tooling and a Y axis. If you do not have both you will NOT be able to mill a Hexagon on your parts. |
not nessary, all you need is C-axis or polygon turning live tool with fix ratio gearbox.
__________________ The best way to learn is trial error. |
| you are both right and wrong, poly-milling is also known as polyform milling and yes, it can be achieved using x/z/c or x/y/z on a turning center. Dont confuse this with polygon turning, for which you do need a syncro tool drive with the spindle, 1:1 or 2:1 to produce a hexaon for example. polygon turning is very damaging to a lathe if the material is tough, it knocks the hell out of the tool drive and the spindle, due to intermittent cutting. But they are totally different functions. |
| I think if you don't have live tooling, then the only way to get a polygon of any sort is going to be rotary broaching. It can be internal or external. Lots of power needed, from what I've heard. Maybe. Never had to do any. |
| For Poly turning or creating cam type profiles have used aTakisawa CNC lathe Which had a Ceramic Y axis Programmed in relation to the Spindle revolution no live tooling. Have produced Poly milling with C axis and live tooling other machines. |
| It's an interesting process...I know I saw a chapter in the machine manual for a Mori Seiki lathe I used to have and most recently, thought , I saw a chapter in my hardinge C-42 manual, but haven't relocated it yet. |
