Results 1 to 3 of 3
Thread: Hardinge Conquest T42 CNC Lathe
    Jul 2010
    Spindle:
    Using control panel pressing cs should start my spindle at 25 rpm.
    It starts a 0 using my speed override. I can get the rpm's only to 10.
    Is this a parameter problem, if so can this problem be fixed?
    Feb 2011
    Does it go higher than that if you enter it in MDI mode?
    Jul 2010
    Thank you for the information!!
    Using the control panel and pressing CW or CCW starts my spindle at 0 using my speed override. Each push of the button should increase my spindle RPMS by 25 RPMS. First push of the button increases it to 10 RPMS and will not go any higher.
    MDI mode works fine. I think the override is not working correctly?
  1. hardinge conquest 51
    By mikemck in forum Hardinge Lathes
    Last Post: 10-15-2010, 08:28 AM
  2. Need Help!- Hardinge Conquest 42
    By newc in forum Hardinge Lathes
    Last Post: 02-25-2010, 07:10 AM
  3. Replies: 1
    Last Post: 11-03-2008, 08:44 PM
  4. Hardinge Conquest 42
    By cncdiag in forum Fanuc
    Last Post: 05-20-2008, 08:06 PM
  5. Hardinge Lathe-Conquest T51SP
    By jkuche in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 01-17-2008, 07:35 PM
