I'm looking at a new BUCK Power Chuck made custom by Buck for Haas TL-15 and TL-25 lathes, available for a significant discount from the manufacturer.
It has an M40x1.5 draw tube thread, and a 10mm draw action.
I'd like to determine if I can adapt this chuck to my CHNC-I, but I have no drawings for the draw tube, or info on the draw tube actuator (i.e. the distance it travels while pulling the draw tube.)
If I knew what the draw distance is, the thread size on the inside of the spindle actuator, the distance to the face of the spindle, and the max bore diameter, I could fashion an intermediate adapter between the two. Basically, one end would screw into the chuck's M40x1.5, and the other end would be threaded to fit into the machine.
I know the obvious answer is, look at your lathe and measure, but the lathe is coming in several days, and the auction is ending soon.
Any help is greatly appreciated.
Torin...
