Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 09-26-2011, 06:37 PM
dfrey2@rocheste is on a distinguished road
Need help with conquest 10-65
Running a program where I stop the spindle after first side is finished, flip the part and finish 2nd side. The problem is when the program hits M00, I can't restart the machine without resetting the program and then searching down to where I want to start the 2nd part of the program. Is there a parameter that I can change that will allow me to open the collet without resetting the program?
Thanks in advance
D
Old 09-26-2011, 07:00 PM
txcncman is on a distinguished road
There may be a parameter you can change, but for some reason I am thinking there is an M-code you can use to tell the machine to ignore chuck/collet open/close signal. Look in your manual for such a code.
http://www.kirkcon.com/
Conquest 250 wbp CNC Machining Centers 3 06-24-2011 10:01 AM
hardinge conquest 51 mikemck Hardinge Lathes 1 10-15-2010 07:28 AM
Need Help!- Hardinge conquest 42 gyroxis Hardinge Lathes 1 09-20-2010 08:07 PM
Conquest T-42 Hydraulic imac Hardinge Lathes 3 04-27-2010 03:04 PM
Need Help!- Hardinge Conquest 42 newc Hardinge Lathes 1 02-25-2010 06:10 AM
