Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 09-26-2011, 12:20 PM
ZenoTech is on a distinguished road
Hardinge CS-51 x/z axis will not home
Just purchased a used Hardinge CS-51 with Fanuc 32-bit O-TC and had it shipped to the shop.
I cannot home it, and without it being homed I cannot start production.
The machine will not return to home position when the auto-zero key is pressed. The machine will move in the (+) position , but will not move in the (-) position unless the E-Stop Override is held. Verified all of the parameters in the provided manual, and the machine worked in the shop previous to the new one. I followed the manual homing procedure from the manual but both axis hit the physical OT position prior to reaching the home position.
Any help would be great, thanks.
-Zeno
Old 09-26-2011, 12:28 PM
txcncman is on a distinguished road
Something was shaken loose during the move?
http://www.kirkcon.com/
Old 09-26-2011, 12:38 PM
Everything seems tight and secure, I removed the rear access panel and tested all the connections, wires, and dogs. Everything seems to be snug as possible.
Old 09-26-2011, 12:44 PM
yours_prabhat is on a distinguished road
See the input is in mm or in inches , also check wheather Mirror Image is On or off , also check can+P while power up , If problem persist Please feel free to communicate on prabhatmishra@gmx.com
Tags
hardinge, homing, issue, lathe
Adding 4th axis to Hardinge w/fanuc BobM3 Fanuc 4 01-08-2012 12:15 AM
Need Help!- Hardinge superslant x axis brake is on Sabrina_B Hardinge Lathes 8 10-08-2011 07:09 PM
Need Help!- Hardinge with Siemens 810T 3-axis topcnc Hardinge Lathes 0 09-08-2010 10:08 PM
Hardinge Conquest won't home? Jim Wilson General Metal Working Machines 1 11-01-2007 11:44 PM
