Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 09-17-2011, 01:34 PM
bobancurug's Avatar
bobancurug is on a distinguished road
Hardinge Conquest T 42 FANUC 0T optional parameters
Hi all
Hardinge Conquest T 42 FANUC 0T system.
I need the optional parameters 900-920. If someone has the same type of machine with this system I would be grateful to him to send me.
Thanks,
Boban
Old 09-23-2011, 06:13 AM
bobancurug's Avatar
Hi all,
I still did not find these settings, if you have someone who has the optional parameters of 900 to 920 would like to send them to me. Machine I still can not run.
thanks
Old 09-23-2011, 12:29 PM
Lewertek is on a distinguished road
You are not providing enough or correct information. Hardinge T42 only sold with 18T control. You must have a CS-42, which was built with either an OTB and OTC control.
I suggest you contact Hardinge with your machine serial number (located inside the headwall by the spindle). They keep all machine parameters on record, and will provide them for a fee (200$ was the going rate last I heard, but may be supplied for free if you are the original owner)
Old 09-23-2011, 12:59 PM
bobancurug's Avatar
Thank you Lewertek because you corrected me.
Yes, it's only a Hardinge Conquest 42, I have two CNC lathe HARDINGE Conquest T42 with fanuc 18t system.
I accidentally typed T.
Thanks again.
I contacted Hardinge but I can not find the machine SNo and they can not help me. I have no documentation of the machine, it is a major problem. I bought it without any documentation.
Old 09-23-2011, 01:21 PM
Al_The_Man's Avatar
PM me with email add., I may be able to help.
Old 09-23-2011, 02:51 PM
For the serial number: Open the collet closer acces door on the front of the machine, look on the backside of the machine headwall, just to the right and in front of the spindle headstock, there should be a small stamped plate with a number CS-XXX.
If it has been removed, I'd suspect it to be a stolen machine or else involved in some other fraudulent activity.
Old 09-23-2011, 04:08 PM
Al_The_Man's Avatar
Per email here is saving the 900's.
Old 09-26-2011, 02:38 PM
bobancurug's Avatar
Today I finally got the original parameters of the manufacturer Hardinge.
How was I happy ... but not for long ....
First I deleted all parameters.
Than I once again inserted the optional parameters until I reached the 910.5 parameter when the system again crashed.
914 ram parity error (servo) reappeared at boot time.
I repeated everything again and once again on the same parameter the system crashed.
I suppose that it was a memory on the motherboard or axis card problem.
Has anyone had experience with this already, and some easier solution?
Old 02-08-2012, 03:20 PM
Thinker4Life is on a distinguished road
T-42 Conquest SP Lathe 900's Paramaters
900,) 0011 1110
1,) 1100 1000
2,) 0010 0100
3,) 1000 0100
4,) ---- -----
5,) ---- 0100
6,) 0010 1000
7,) 0100 1010
8,) ----- -----
9,) 0100 -----
910.) 0110 -----
11,) 1000 -----
12,) ----- -----
13,) 1000 ------
14,) 1000 ------
15,) ----- -----
16,) ------ -----
17,) ----- 0010
18,) ------ ------
19,) ------ -------
Need Help!- Manuals of Hardinge Conquest VT100, GE Fanuc 18-TB (Power BT-113469), S/No. VL-338-2 ejaz199 Hardinge Lathes 0 12-22-2010 04:17 PM
Need Help!- Manuals of Hardinge Conquest VT200, GE Fanuc 18-T B (Power BT-110618), S/No. VL-450-2 ejaz199 Hardinge Lathes 0 12-22-2010 04:12 PM
Need Help!- Hardinge conquest 42 gyroxis Hardinge Lathes 1 09-20-2010 08:07 PM
Need Help!- Hardinge Conquest 42 newc Hardinge Lathes 1 02-25-2010 06:10 AM
Hardinge Conquest 42 cncdiag Fanuc 1 05-20-2008 07:06 PM
