Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 08-15-2011, 03:05 PM
joeski63 is on a distinguished road
Remastering a Conquest GT27sp
Good Afternoon Gentlemen,
I had my GT27SP off for a week or so and I need to zero return my machine in both X and Z axis's.My battery went dead,and I have absolute encoders. I have done this before on my conquest 42 and the repair manual for the GT only covers this in the switch replacement part and wants me to adjust in the 1850 parameter.Any body know the proper procedure for doing like to move it within .100 of home and hit zero return?Thank you for your time.
Joe
Old 08-17-2011, 08:45 PM
Nawrocki4Life's Avatar
Nawrocki4Life is on a distinguished road
Abs home set-up
Hope this helps you put.
1.) Set parameter write enable to "on"
2.) Look at parameter 1250 for inch home positions of machine and keep that value in mind for later.
3.) Pick a axis
X-axis is basically located that the back of the top plate is 3 inches from center of spindle. So you'll need a piece of stock in spindle a flat piece of stock and a "jo-block" Mount stock in spindle and divide the O.D. by 2. then get a slip fit between the flat stock (placed flush on back of top plate) and "jo-block" Add the "jo-block" length plues half of the stock's O.D. Then use the reletive position register and input that value there. Once thats complete jog x axis to the home position (1250 value). USE RELETIVE POSITION REGISTER NOT MACHINE POSITION FOR THIS!!! once axis is there go to parameter 1815 and change bit 4 "APZ" for "X" to a 1. Then cycle control power.... Complete
Z-axis is the same procedure but its position is from the face of the spindle (not collet) to the face of the top plate. Once again use a "jo-block" again and get a slip fit. once thats achieved, put that value of the block in the reletive position and use that register to jog z to the home position. Then the rest is history..... Hope that helps you, GOOD LUCK!
Old 09-12-2011, 02:49 PM
Thank you
All is well the information worked just fine
Thanx
Joe
Conquest 250 wbp CNC Machining Centers 3 06-24-2011 10:01 AM
Need Help!- Hardinge conquest 42 gyroxis Hardinge Lathes 1 09-20-2010 08:07 PM
Conquest T-42 Hydraulic imac Hardinge Lathes 3 04-27-2010 03:04 PM
Need Help!- Hardinge Conquest 42 newc Hardinge Lathes 1 02-25-2010 06:10 AM
Hardinge Conquest 42 cncdiag Fanuc 1 05-20-2008 07:06 PM
