Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 07-05-2011, 03:20 PM
GTD222 is on a distinguished road
HElP alarm 1044!
Hello all, I have a hardinge t42 sp that over traveled and now I can not get the X torque limiter alarm to clear. e stop is on, you have to pull and hold down e stop reset to move axis.
I have tried doing what the manual says to no avail. I had to other processes sent to me from hardinge but i dont have all the options that they want you to push.
can anyone help me out with this one?
Old 07-05-2011, 08:54 PM
ppascuzzi is on a distinguished road
Is this what you tried?
1. Pull out on E-Stop pushbutton (74) and simultaneously press E-Stop Reset pushbutton
(73).
2. Select the X axis Handle MPG mode.
3. Make certain that the Handle mode is in .0001 increments (previous page, step #4).
4. Monitor Diagnostic X10 bit 3 (XTQLM) and very slowly rotate the handle in the X axis
plus direction until X10 bit 3 changes from 0 to 1. A distinct popping sound will be heard
when the torque limiter resets.
When X10 bit 3 changes from 0 to a 1, the torque limiter will be reset.
9-2 M-322
5. Set the control as follows:
A. Turn the Control OFF.
B. Turn the main disconnect switch OFF and wait 1 minute.
C. Turn main disconnect switch ON.
D. Turn Control ON.
E. Reset E-Stop by pulling out on E-Stop pushbutton (74) and simultaneously pressing
E-Stop Reset pushbutton (73).
6. Test jog the axis. Complete the torque limiter reset procedure by continuing with the
X-Axis Zero Return Setup
If that doesn't work on a T42 something is likely wrong or out adjustment with the torque limiter or prox switch. Sometimes the old torque limiters get a little "sticky" try hand wheeling the axis down to a save location and jiggle the mpg hand back and forth a bit to shake the limiter a bit then try reseting it again.
Old 07-06-2011, 12:07 PM
yes, except all the bits were 1. none were 0 indicating a trip
Old 07-07-2011, 01:24 AM
That means you have reset the physical torque limiter. Now finish the procedure from the book. Step six says to "Complete the torque limiter reset procedure by continuing with the X-Axis Zero Return Setup" The alarm will not clear until you begin the x axis zero return procedure.
Old 08-05-2011, 03:24 PM
Steamie is on a distinguished road
Hi, did you reset x home position
Using the relative page and preset, if
So can you remember how!
Cheers
Problem- (ALARM 414 SERVO ALARM) Y-AXIS DETECT ERROR? PICMAN Fanuc 9 Today 01:32 PM
Problem- Daewoo DMV3016 Mill Alarm (Spindle tool clamp/unclamp alarm) nickhough Daewoo/Doosan 0 05-09-2011 11:22 AM
Calcomp 1044 GT TZak Printing, Scanners, Vinyl cutting and Plotters 11 02-18-2011 01:33 PM
ALARM shuttle drawbar alarm haas timmydabull Haas Mills 27 10-30-2009 08:27 PM
Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm doubleeagle Daewoo/Doosan 4 06-12-2009 03:15 PM
