| Hardinge Lathes Discuss Hardinge Lathes here. |
I have a customer who had me wire up and wants me to setup his CHNC 1 which is all functioning Good. I have written the program, and the problem I am faced with... and cannot find an answer to... after reading the 384 page manual... is how do I get it to run in Auto mode... without it stopping every time... I can get it to run by pushing "Setup" It is then in Setup mode... and it runs through my program, one block at a time. When I turn off Setup Mode by the switch, and try to run in Auto mode, it simply does not start... and I can see the Single Block button turns off single block and back on... top right of screen... but will not start and continue... What am I doing wrong? Any help will be appreciated... need to get it to run a program continuously... till the end... like it should. - Jeff |
| Thanks, No alarm... I am new to the machine, and it was a good running machine from where it was bought... so I think I just don't know something about loading a program and running it. I did figure out how to home the machine... and that works good. Each axis. X and Z. It appears the front door up, is "wire nutted"... or bypassed. Looks like the air pressure sensor was bypassed as well... The lube? Would not that give a error message, to fill it? Just wondering on that? |
| Need Help!- Adding Auto Mode | Jerry Shorter | LinuxCNC (formerly EMC2) | 5 | 06-17-2010 08:38 AM |
| Auto mode only after single block | fomaz | Fanuc | 7 | 04-17-2010 04:53 AM |
| Need Help!- T MSR AUTO MODE IN MAZAK! | sridhartsr | Mazak, Mitsubishi, Mazatrol | 2 | 03-28-2009 04:34 PM |
| Problem- Okuma LB-15 Sinble blocks in auto / single block off. | mcrosby | Okuma | 3 | 03-23-2009 08:57 AM |
| Single line mode works well, Auto is not soo good?? | Darc | CamSoft Products | 16 | 10-26-2004 03:29 PM |
