Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 05-13-2011, 11:31 AM
*Registered User*
lyfordln is on a distinguished road
DC motor voltage
I have a HNC Hardinge that I want to retrofit. How can I find out what the motor voltage is. They have only two wires going into them,
Old 05-13-2011, 11:40 AM
Al_The_Man's Avatar
A simple but fairly accurate test is to back feed them with a known rpm, measure the DC output from the two armature wires.
Many older DC servo's, especially the larger sizes were limited to 2000~2500 rpm.
So extrapolate the DC required for those rpm from the results of the test.
Alternatively you could feed them with a couple of automotive batteries in series and measure the voltage and RPM and calculate the same way.
Old 05-17-2011, 11:46 PM
Zoni is on a distinguished road
hi the dc voltage are about 150 volts
Newbie- Motor voltage issues Greg King DIY-CNC Router Table Machines 6 10-07-2009 10:07 PM
Gecko Motor Voltage? GrahamIT Gecko Drives 4 01-14-2008 02:19 PM
Brushed DC motor voltage? bunalmis Servo Motors and Drives 2 11-09-2006 03:23 PM
motor voltage planescott Stepper Motors and Drives 2 12-28-2005 09:28 PM
servo motor voltage? tpworks Gecko Drives 2 04-17-2004 02:34 AM
