Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 04-06-2011, 04:50 AM
Jnice is on a distinguished road
Post Machine manipulation
I'm using a hardinge with a fagor 8025t control, when calculating dimensions and entering them into my program, I'm not getting what is should be. Is there annoying I can do so I don't have to lie to my machine and scrap parts making adjustments? Is it my tool radius? I have my tool radius set, should I have it on zero instead? Will my machine make up the difference?
I have 2 hardinge lathes with 8025t controls. On one lathe to get a radius on round stock I simply add the size of the radius to my -z and subtract it from my dia.
On the second I have to take my radius add my tool radius to my -z the double that and subtract from my x.
Why?
Old 04-06-2011, 07:41 PM
g-codeguy is on a distinguished road
Why?
It would only work that way if one is set up for radius programming and the other for diameter programming. They both couldn't be set up for the same method of programming (both diameter or both radius programming). If they were, one would be giving you an alarm that the arc was out of tolerance. At least that is the way that it works with the four 8025 lathe controls we have.
Old 04-07-2011, 02:51 AM
Is there a way I can determine which of the two my machines are programmed for? What is the difference between the two as far as creating programs goes? Is this something that can be changed? And if so will it alter any existing programs?
Any and all information is greatly appreciated as I have exhausted myself with studying the programming manual and have multiple questions with no answers!
-J
Old 04-07-2011, 06:18 PM
This lathe is set up for radius programming. If you program
X.375Z.02
G1Z-.7F.004
it will turn a .75 diameter provided your tool geometry is set correctly.
This lathe is set up for diameter programming.
X.375Z.02
G1Z-.7F.004
will turn a .375 diameter.
See above.
You've already discovered the difference. A .875 diameter has to be programmed with an X.4375 when the lathe is set for radius programming.
Part radius + insert radius subtracted from the diameter is the correct X-starting point (for an OD radius) on the lathe set for radius programming. 2*(part radius + insert radius) subtracted from the OD diameter is correct for the lathe set to diameter programming.
Yes. It should be a simple parameter change. I would have to look in our manual to see if I can find it for you.
It won't alter the programs, but you will have to. If you switch the radius programming lathe to diameter programming, then all your X-dimensions in all the previously written programs for this lathe will have to be modified.
Most people program in diameter. Easier to program. Simply take the diameters directly from the drawing. Less chance for errors. Easier for the operator to understand. I personally think it is worth the effort to set both lathes to diameter programming. Less confusion. When an operator walks from one to the other, he isn't always trying to remember which is which.
Plus, if I remember correctly, X-offsets work the same way as programming. A .003 offset on the lathe set to diameter programming will move the diameter .003, but will change the diameter by .006 on the lathe set for radius programming.
Old 04-10-2011, 06:06 PM
on the lathe thats believed to be set up for diameter programming, i have a facing program, and lets say i need a 45deg.x .05 +/- .01- in order to achieve a chamfer close to this spec here is my procedure;
1.003-.032(tool radius)-.094=.877 my program will look like this because i have no coolant and want a good finish
g0 g90 g70 g07 t01.01 s2500 m3
x1.025
z0
g92 s3000
g96 s300
g1 x-.05 f.005
x.877 f.008
x1.003 z-.062 f.006
x1.03 f.01
g0 z2.5 m5
m30
Old 04-10-2011, 11:34 PM
First let me say I would not face down and then back up. I do believe in facing from the outside towards the center. The only time I don't is when the wall is thin enough to feed into the face, and then face up. This is seldom for the work I normally do. Using your specs, I would program it this way:
G0 G90 G70 G7 T01.01 S2500 M3
X1.025
Z0
G92 S3000
G96 S300
G1 X-.065 F.005
Z.01
G0 X.8464
G1 X1.003 Z-.0683 F.003
G0 Z2.5 M5
M30
.0183 is the tool nose radius compensation for a 1/32R insert at a 45 degree angle. Some manuals have a chart for TNRC for each whole degree from 0 to 90 degrees and for several different radius inserts. All you really need is from 1 to 45 degree. Just reverse the X-Z values from 46 to 89 degree.
My program would look a bit different as I always swing a radius at all corners to remove any burrs unless the drawing specifically specifies a sharp corner. A .05 x 45 degree chamfer with a 1/32R insert (I use .031) and a .005R on the part would look like this:
G1X.8368Z0F.003
G3X.8878Z-.0105R.036
G1X.982Z-.0576
G3X1.003Z-.08331R.036
G1X1.007Z-.11
OR
G1X1.03F.015 if you preferred a straight pull out move.
This would be a finish move. I would always first make a rouging pass on a chamfer this large.
Old 04-11-2011, 08:47 PM
Im impressed with the level of technicality in the program, when you rough with no coolant what is your g92 and g96 at? also what feed rate do you use?
when in rapid traverse what is the distance you travel from the workpiece? if i wanted to make a rough pass the g0 back for a finish could i trust my machine to not crash at a distance of .05? if this is the case i will change all my programs over to get the same effect on all my parts.
because of you and your advice of reading the manual, i have learned more about this machine in 7 months than my co-workers have since the got the machine 9 years ago! ive ordered a finish tool but, my co-workers are upset with me because of this, so im going to wait before i install it. i have a cutoff installed up to 1 inch, but i have no coolant. so im trying to find the best speed and feed to save inserts.what would you recommend?
again thank you for your help, its appreciated as always.
J-
Old 04-12-2011, 07:20 PM
It depends on the material, DOC, machine's horsepower, etc. Three of our Fagor controlled lathes are manual Hardinge lathes that were converted. One is rated at 1/2 horsepower! The other 2 not much more. The CMS has the most, but these are not really machines for roughing. I have no idea about yours, but if they are similar to ours...and you have to rough...take shallow DOCs at higher feedrates. Higher feedrates being relative. F.005/.008 is high on our lathes taking .02/.03 DOC...again depending on material.
I have to be careful with drills/endmills because I can easily stall the spindle. Normally this is only when I am drilling out a soft collet before boring it to size. I may have to start small (say 3/8 in.), and step drill size up a time or two.
I normally set the G92 to the lathes maximum RPM unless the part is getting too hot. I'll run the G96 a bit slower than when using coolant. If I run a certain grade of insert at 450SFM wet in 316 SS, then I'll probably run it at 350SFM dry.
Normally I use .02 clearance. Example: face and turn 1 inch material to .95 diameter with 1/64R insert. .005R on part.
G0X1.04Z0
G92S3500
G96S600
G1X-.035F.0035
Z.02F.006
G0X.96
G1Z-.75
X.98
G0Z.02
G1X.89F.015
X.908Z.005
Z0F.002
G3X.95Z-.021R.021
G1Z-.75F.0035
X.97
G0G97Z.5
The funky move at the face of the part is to remove any possible backlash. I use to use the .02/.005 approach for boring bars also, but came to feel I was pushing my luck with some of our operators. I now use .01. Example:
X.57Z.03
G1X.542Z.01F.015
Z0F.002
G2X.5Z-.021R.021
G1Z-...F.004
Again it depends on material. I've been told that some grades such as M93 from Manchester like heat. It supposedly makes the coating even harder. Cut-offs are one tool I don't try to push. We don't barfeed on our Fagor controlled lathes. Only time I cut-off is when I'm making coolant balls, and I use a narrow double ended Sandvik groove tool. The CMS is the only Fagor controlled lathe we have that could use a 1/8 inch cut-off insert. Even then I'd be skeptical in tougher materials such as stainless steels.
Depending on horsepower, I wouldn't feed any faster than F.002/F.003 (I'd use F.002 to start with if the machine can handle it). Limit max RPM to about 2000/2500. Run SFM at about 50-75% of what the insert catalog suggests to start. If it looks good and isn't getting too hot, increase the SFM a little at a time (maybe 10% increase each time).
J-
No problem. Glad to help when I can.
Tags
8025t, chamfer, fagor, lie, radius
Need Help!- Hardinge CBN Turning Machine with GE Fanuc Machine Model CS- 51, S.No. CL – 622 -BSP M.RISHIKESH Hardinge Lathes 1 11-20-2009 06:03 PM
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 09:37 PM
Acad 2000 Solids Manipulation Question mcyr Autodesk Software (Autocad, Inventor etc) 4 05-13-2007 03:01 PM
