Results 1 to 3 of 3
Thread: chnc 1 control problems please help
    Oct 2006
    I just bought a chnc 1 from a heavy equipment company that had this machine sitting in their warehouse for about 2 years. They said the machine was up and cutting when they got there to disconnect the machine. When I got the machine hooked up it gave me the control battery error too low so I put a new battery in and now nothing even comes up on the monitor. on the back of the controller (siemens) a nc fault light is on. When I put the old battery back in the controller it boots up and say's the battery too low replace to continue.
    Did I lose all my memory? anyone ever reinstall all the flash?
    thanks
    May 2007
    I'm not maintenance, nor familiar with that control, but it is quite possible you lost everything. I can't speak from experience, but I've been told that is why you change the battery with the power on. Did you?
    Feb 2007
    MEXICO
    yes you lost everything, I have the parametros and the instructions and the program, if you need it, send me you email and I send to you.
    this is my email
    tooldiecomp@yahoo.com
    Have a Nice day
  1. Need Help!- control problems
    By fiat4726 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-15-2010, 04:18 PM
  2. Hardgine CHNC II turret problems
    By CatesMetal in forum Bridgeport and Hardinge Mills
    Last Post: 08-28-2009, 08:14 PM
  3. Need Help!- CHNC II GN10 control Initial start up problem
    By LeftCoastCNC in forum Hardinge Lathes
    Last Post: 07-13-2009, 11:00 PM
  4. Need Help!- Problems using EIA with M32B control
    By pquentin21 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-04-2009, 10:29 PM
  5. Fanuc 5T Control Problems
    By tech1 in forum Fanuc
    Last Post: 08-26-2005, 10:24 PM
