Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 03-03-2011, 08:54 PM
lavrgs is on a distinguished road
Turning parts on a Hardinge HC -need help
I am try to make some bolts on the HC and on my test parts (out of aluminum) I am getting way too much deflection. I expect that will carry over to the parts made from stainless steel. I'm guessing a box tool would help with turning the diameter to provide some support. Is there another way? What's happening is the diameter farthest away from the collet is greater than close to the collet. I used a geometric head to create the threads and they're ok where its fatter and flat topped where its thinner because of the deflection.
I will be using 7/16 hex 303 Stainless for the final parts. I'd guess it wont flex as much but would not produce "perfect" threads either.
Bill
Old 03-04-2011, 02:52 PM
ss_again is on a distinguished road
deflection = (P*L^3)/(3*E*I)
P = load,
L= length from spindle to end of rod,
E = modulus of Elasticity,
I = moment of inertia of a round cross-section.
For an estimate of what the deflection will be for the stainless, swap out the "E" for the aluminum for the "E" stainless after you back calculate the applied load "P" since you already know the deflection for the aluminum.
Typical "E" for aluminum is 10.3e6 and 29.0e6 for steel.
If I had more time I'd do it for you but I don't right now sorry.
This will just give you an estimate as there are other variables that come into play like the changing diameter but since the "E" of the steel is approx. 3 times that of aluminum, you'll see about that much difference in deflections.
Old 03-05-2011, 01:15 PM
JimBoyce is on a distinguished road
Divide & conquer may help. Turn just the thread section to diameter and length. Then turn the rest of the screw. Then thread with the die head. If there is tapor and the tapor is consistant, program it out.
Old 03-05-2011, 06:49 PM
...can I really program it out? This is a manual machine...I will try the divide and conquer method as I wait for my box tool to arrive...this is going to be a very expensive bolt between the die head and chasers, box tool and who knows what else...eek!!!
Old 03-06-2011, 11:02 AM
nate is on a distinguished road
what are the part dims?
Can you center drill and use a live/dead center in the tailstock. That would get rid of the deflection (for the most part)
Nate.
Ann Arbor Meechigan
Old 03-06-2011, 02:28 PM
HC lathe does not have a tailstock
It is an M7 bolt and 75mm long (~3 inches oal)
Old 03-07-2011, 07:23 PM
vrn vrn is offline
vrn is on a distinguished road
The box tool is the way to go. Will deffinately take care of the deflection problem.
Need info on Hardinge Superslant SB-3GN CNC Turning Center Crashmaster General Metal Working Machines 7 09-09-2010 09:26 AM
Looking for old Hardinge parts lee green Want To Buy...Need help! 0 07-19-2009 04:19 PM
Good places to find reman parts for a BTC-1 or other hardinge machines Knowklew Bridgeport and Hardinge Mills 2 06-18-2007 11:41 PM
parts for Hardinge HLV-H dango Bridgeport and Hardinge Mills 1 04-12-2007 10:26 AM
Hardinge Way cover parts Gncc50 Bridgeport and Hardinge Mills 3 06-28-2005 05:16 PM
