Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 12-04-2010, 10:14 PM
A1CNC is on a distinguished road
Superslant GN6 Not ready
I just purchased A 1983 Superslant with the gn6 control (2 axis).
When I power it up, it stops before the position page. I have alarm flashing in the lower right corner, and it displays 1000 not ready.
Can anyone help me?
Thanks,
Eric
Old 12-05-2010, 08:53 AM
GN6 not ready
More info,
The hydraulics do not come on, If I press the Emergency re-set the x brake releases but the drives do not kick in.
There are no led's on the main board, The pil light comes on. The correct voltages are present at the power supply, and the power unit but not on the check pins on the main board.
Can anyone recommend what to check next?
Thanks,
Eric
Old 12-06-2010, 06:00 PM
KTECH is on a distinguished road
on ours you have to hold the e reset button for a few seconds and the pump will fire up
Old 12-07-2010, 11:59 AM
KTECH,
When yours goes through the boot sequence, does it show the position page before you press the e-stop reset or after?
Old 12-08-2010, 07:15 AM
No it doesn't. It will first show some alarms at power up then after the hydrolocs are fired up it will show an alarm from not being homed out. It automatically lights up the zero return button. You then jog the axises away from position and back again it will return itsself but becarefull these things are finicky. That's it then your good to go
Old 12-08-2010, 08:15 AM
KTECH
Thanks for that,
I just bought some new bulbs so I can see what buttons are supposed to be lit up now.
I will try holding the e-stop re-set and Pray for the drives to kick in!
Old 12-08-2010, 11:00 AM
Well,
I thought I ordered the correct bulbs, NOT!
I tried holding the e-stop reset, the x-axis just slowly goes down, no hydraulics, no drives. I did see the over travel alarm on X once it got to the botom so I know that's working.
I measured the voltage from the 380v transformer and it is putting out, 394, 401, 402. It looks like I need to find the correct taps on the transformers and see if that is the trouble.
Old 12-08-2010, 12:23 PM
cncserveng is on a distinguished road
Don't worry about those voltages, they are OK. A 380v system can work up to 420v without a problem (+10% max).
If your machine is "not ready" this is usually due to and external fault, emergency stop etc;
have you checked the 24vdc fuses for inputs/ outputs etc; sometimes they show a white tag in a small window when they have blown.
make sure the axis are not sitting on the emergency switches.
Old 12-08-2010, 05:45 PM
Hmmm bummer on that. These old things will not fire up if there is one thing even remotly wrong. I agree on the voltage thing. I wonder if you have some other things going on there.
Old 12-08-2010, 07:46 PM
I was hoping it would be that easy!
looking in the diagnostics, the z axis has a 1 under servo off but the x has a 0 when I press the e-stop reset it goes to 0 but goes right back to 1 as soon as i let go. The Z is not near the limits and both bits are 1's.
When the machine showed up the z was near or on the limit so, after it didn't fire up I moved it a good distance away.
I did find the wiring diagram with the transformer taps today, maybe it's worth trying that next.
  #11   Ban this user!
Old 12-09-2010, 10:37 AM
There isnt any servo alarms present? 400 series is servo drive issues
  #12   Ban this user!
Old 12-09-2010, 11:10 AM
No alarm #'s showing, Just 1000 not ready or 1000 e-stop, I forget which.
I couldn't find 1000 in the list of alarms, does that mean an external alarm?
Need Help!- Hardinge superslant x axis brake is on Sabrina_B Hardinge Lathes 8 10-08-2011 07:09 PM
Hardinge Superslant retrofit kudos LinuxCNC (formerly EMC2) 5 04-05-2010 06:04 AM
m31 on hardinge superslant 6t control winton Hardinge Lathes 2 05-02-2009 10:51 AM
Hardinge Superslant GN-6 RS232 Comm NEC Hardinge Lathes 3 11-28-2008 12:30 AM
hardinge superslant retrofit fcycles General Metal Working Machines 0 02-14-2008 09:15 PM
