Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 12-01-2010, 02:27 PM
xrrcr is on a distinguished road
480 to 240 input on a HLV-H
Newbie needs some help.
Have recently purchased an HLV-H, s/n HLV-H-5378-L. Came from a plant that was 480v 3ph., now need to change it over to 240v 3ph operation.
Sent a request to Hardinge but have yet to get a response.
Anyone out there done this ?
Thanks for the help,
Steve
Old 12-02-2010, 08:09 PM
Nawrocki4Life's Avatar
Nawrocki4Life is on a distinguished road
Voltage change
Hello Steve I will try not to miss anything you'll need to do hear.
Here's a checklist you can look over.....
___ 1.) Check the main motor (directly under the headstock). See if its a dual voltage motor. (will be on the motor's plate.)
___ 2.) Check the variable speed motor (directly under the pan in front of the headstock. Has the vertical lead screw). check for the same
___ 3.) Check the coolant pump/ motor for the same.
If they all are dual voltage motors, you can re-wire them to be for 220 instead of 440. If they are not dual voltage you can either do two things.....
1.) Get a set-up transformer that will be exturnal from the machine and will convert your 220 to 440.
2.) Replace these motors with ones that are for 220.
Checklist continued.
___ 4.) All fuses on primary voltage side will need to be changed. Higer voltage draws less amps the(N) lower voltage so, higher amp fusses will be needed.
___ 5.) The heaters need to be changes as well for the same reason and the same idea applies here as well. These are for overloading the motors. They are located the 3rd row up from the bottom of the elect cab.
Hope this helps you buddy. Good luck.
Old 12-06-2010, 01:53 PM
Am gaining on it
Will give a step by step after the job is completed.
Major notes:
all motors are multi-voltage
all but the main motor have diagrams to change voltage
chasing down 18 wires on it
need to change jumper wires on transformer
Need some input verga DIY-CNC Router Table Machines 5 04-19-2010 09:32 PM
3 phase input VFD for single phase input? Redhead Phase Converters and VFD 4 02-27-2008 10:30 AM
Newbie- I need some input hcker2000 Benchtop Machines 2 02-18-2008 07:17 PM
Newbie- stl input jcoats CamBam 1 02-09-2008 01:40 PM
I need some input Steve@Reliance CNCzone Club House 2 09-27-2006 03:54 AM
