Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 11-03-2010, 08:58 PM
rockchopper is on a distinguished road
GN6T-c control and RS-232
Anyone know if GN6T-C control uses a null modem? I pick up a used 1986 Hardinge Super Slant with this control. I've tried transfer from the control to the PC. using E,7 and 1 with Xon X off. Tryed 9600, 4800, 1200, and 600 baud rate. with no luck. The LSK flashes on the control and PC software indicates that has received a file, but when you click OK there is nothing in the file. I'm using a DB9(pc) pin to DB25(control) pin null modem cable. I think the cable config is the problem
Need Help!- Velocity Control Drives and Fanuc 2000C control redialtone Fanuc 3 06-21-2010 09:26 PM
Cards Support Stepper Motor Driver Control & AC Servo Control. Johnnyatcnc Product Announcements & Manufacturer News 0 04-09-2010 03:57 AM
fanuc GN6T ChrisCharby Fanuc 3 12-18-2009 08:42 AM
15i control help for (AiCC) (hpcc) high precision contour control programming gibbsmaster Fanuc 2 12-28-2007 09:57 AM
Using Flashcut CNC Spindle rotate card control to control laser power pyroplotter FlashCut CNC 0 10-15-2007 09:46 PM
