Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 10-17-2010, 02:10 PM
rboldt is on a distinguished road
CHNC I - Start up
I just purchased a Hardinge CHNC I lathe and tried to start it up without a manual. I have a manual now and found out that I pushed the home button a couple of times before I was supposed to. There is a error code stating that there was -X axis over travel. Anyway, the slide won't jog at all now. Can someone tell me how to get it going again. Thanks.
Old 10-18-2010, 01:26 PM
I got the machine to jog. I had to turn the X axis ball screw by hand in the "+" direction and then it worked. However, when I went through the homing process, the Z axis was fine but the X axis doesn't come close to the dimension that the book calls out before it bottoms out in the X+ direction. The centerline of the turret is supposed to be 3" from the centerline of the spindle, but it is roughly 1/2 to 3/4" short. It doesn't look like it will ever get to that dimension. Now, when I try to home the X axis, it bottoms out and gives me a X axis overtravel fault. Can anyone help??
Old 10-28-2010, 10:00 PM
wmpy is on a distinguished road
I don't know if it's too late to help you, but if your machine has the Fanuc 0T control, try pressing (and holding down) the JQP button and the Cancel button at the same time while powering up the control. Once it's powered up, try homing the machine again. If that doesn't work, post up here again, and I'll give you some more things to try.
Old 10-29-2010, 07:00 AM
Thank you for responding. I found a service tech. that told me to do what you also recommended and that solved the problem!! The machine now homes out like it should. Thanks again.
CHNC 1 HELP !!!! garnetram Hardinge Lathes 4 10-15-2010 10:34 PM
Need Help!- CHNC II GN10 control Initial start up problem LeftCoastCNC Hardinge Lathes 1 07-13-2009 10:00 PM
Need Help!- CHNC II+ race8082 Hardinge Lathes 0 07-11-2009 12:53 PM
Arrow 750 Failed to start when I Push start Bottom in fornt of control ! mte.jalal Cincinnati CNC 4 01-06-2009 10:20 AM
chnc brians machine CNCzone Club House 2 04-08-2008 04:33 AM
