Results 1 to 6 of 6
Thread: Hardinge CHNC CNC-594 Retrofit beginning.
    Oct 2005
    us
    I have contacted Hardinge to see what they can tell me about the year and model of this lathe. Sadly, the man at Hardinge, was of little help. I have little faith that I will even get a call back. Oddly, I called Hardinge, and he said he needed to contact hardinge to get the info. Seems that I might have called the "parent" company?
    Anyway, I had been looking for a medium sized CNC lathe for a mach3 retrofit, and I snatched this off ebay for a bit over the scrap value.
    I will be more or less gutting it. It will get an AC motor and VFD, Stepper motors and G203V controlers. This will be my 4th retrofit, the most recent being a late 80's bridgeport.
    I will be scrapping the indexing turret and using gang tooling.
    I have ordered a maintenence manual, but am having a very hard time finding out much about these lathes. Does anyone have any info they could provide?
    I am very interested in a parts list or at least a part number for the Y axis ballscrew. The Z screw was allegedly replaced by the PO, but the Y screw is a bit crunchy. No real backlash, but the initial movment is a bit "twitchy" once moving, it smoothes out considerably.
    I would like to take out the Y axis screw and take a look at it, but I am unsure how to remove it. Any hints?
    Looking forward to any info you care to share...
    Nate.
    Nate.
    Ann Arbor Meechigan
    Jun 2005
    Nate,
    what model chnc do you have? i had a chnc I and i have all the manuals for it. mine was also a seimens control. your welcome to come and pick up the manuals as i'm in sterling heights. i would forget about the stock ball screws for the x and z if you really want a gang style lathe. the x axis screw is so short that you won't be able to get enough tools on there.
    hardinge also closed their in house tech support and its now run by another company that knows very little about these machines and they have no factory training.
    Jerry
    Oct 2005
    us
    WOW
    wow. I am definately going to take you up on the manuals!
    I got your number in the PM. I will call.
    Thanks!!!
    Nate.
    Ann Arbor Meechigan
    Oct 2005
    us
    Pics.
    Thought I would upload a few pics. first is the machine, then some pics of the motor mount plate and the modification of it.
    Nate.
    Ann Arbor Meechigan
    Aug 2009
    I've got the same machine ser 119, that's been retrofitted with a Fagor 8025.
    I've made gangtool setups to bolt onto the turret. 4.5" of X travel sucks but it works.
    Apr 2005
    Year of manufacture CHNC
    If it helps I have serial # 587 and per Hardinge is was shipped to the first owner September 22nd 1980
    1. Advice on Hardinge CHNC retrofit
      By rkdygert in forum Mach Lathe
      Last Post: 08-14-2012, 04:04 AM
    2. Hardinge chnc retrofit cnc
      By jheyliger in forum General Metal Working Machines
      Last Post: 02-28-2008, 05:48 PM
    3. Help! My Hardinge CHNC Retrofit Project
      By rpseguin in forum Bridgeport and Hardinge Mills
      Last Post: 07-10-2007, 12:43 PM
    4. Hardinge CHNC Retrofit
      By cbucner in forum Vertical Mill, Lathe Project Log
      Last Post: 12-29-2006, 09:57 PM
    5. Hardinge CHNC retrofit
      By Karl_T in forum CamSoft Products
      Last Post: 09-09-2004, 09:49 PM
