| Hardinge Lathes Discuss Hardinge Lathes here. |
I have a HLV-H and am having trouble with my londitudinal power clutch feed. When I begin to cut it is slow to engage then it stops. I have to coax it to continue. It goes a bit more and then stops again until it is about 1.5" from the spindle. Then it goes for about 6" and then stops again. Can anyone help with this? |
| HLV-H clutches only have a release adjustment (accessible under the screw cover). Could be worn plates (has the clutch been slipping for a while?) I suppose it is just possible the nut that holds the bearing and spring in place has become loose. Have you changed the apron oil lately (Hardinge recommend automatic transmission fluid - TQF etc. every 6 months) Bill
__________________ Bill |
Bill, Thanks for all the suggestions. I just got the lathe so I am not sure how the previous owner kept up with maintenance. I replaced the ATF, but that didn't help a whole lot. The problem seems to happen at around the same place each time and that is close to the spindle. It makes me think that something is worn. Is it a difficult project to replace the plates? Or maybe to check to see if the spring is loose? Thanks for your time. Bob |
| The clutches are suppose to slip if the load is excessive, so it'd be worth checking for damage to the bed or anything else that could be stopping the carriage.
There are some pictures of my apron here in my i HLV-H rebuild
To remove the apron front: remove all allen bolts, pull at the bottom and tap around the sides firmly with a soft faced mallet to crack the sealant. Tap it back on and off and around the edges until it pulls free (DO NOT lever). While you're there, check the carriage drive gear and bearings (they will probably be worn and worth replacing while it's apart) If in doubt, ask I'm happy to help (I received plenty when I did mine)
| Need Help!- Replacing Reverse Clutch Rod | ehavens | Knee Vertical Mills | 1 | 05-07-2010 11:04 PM |
| Bendix clutch | Chubs | Jet Engines and Ram Jets | 9 | 10-02-2007 11:02 PM |
| found clutch | mdreitzusa | Mechanical Calculations/Engineering Design | 7 | 09-30-2005 11:35 PM |
| Electic clutch | Konstantin | General Electronics Discussion | 0 | 09-02-2004 12:12 AM |
