Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hardinge Lathes
Hardinge Lathes Discuss Hardinge Lathes here.
Old 04-08-2010, 06:16 PM
ParkerMillguy is on a distinguished road
Quest 6-42 turret reset
We lost our Turret position with a battery swap. The Turret is not clamped...Does anyone know how to "zero" the turret?
Old 04-16-2010, 06:35 PM
Nawrocki4Life's Avatar
Nawrocki4Life is on a distinguished road
Lost turret position
I work for one of the dealers that Hardinge droped. Sorry bc the new guys are in for a world of trouble...hahahahaha
here is the set up for a turret with abs encoder......good luck!!!
Go to MDI mode
2. Press System Key
3. Press pmc parameter softkey
4. Press keeprl softkey
5. Set K0.6 to a 1
6. Change to Jog mode
7. Press Collet Open/Closed button to unclamp the turret. (Light will be ON when turret is unclamped)
8. Jog the turret using the handwheel all the way back around to the mark again.
9. Press Collet Open/Closed button to clamp the turret.
10. Go to MDI mode, Press System key
11. Press param softkey
12. Key-in 1815 then press NO.SRH softkey
13. Set parameter 1815 bit 4 "3" = 1 ( might be "A" instead of "4") DEPENDS ON IF YOU HAVE A SUB SPINDLE OR A TAILSTOCK. The right parameter will have a "1" in the bit after.... bit 5 witch is APC...... DDO NOT CHANGE THE APC PARAMETERS>>>>JUST THE APZ!!!!!
14. Press E-stop
15. Turn Off control
16. Turn control On
set K0.6 to a 0 then you are done.
Last edited by Nawrocki4Life; 04-16-2010 at 06:39 PM. Reason: forgot one thing....sorry
Old 04-21-2010, 02:53 PM
Thanks Naw...We ended up paying someone to come in and do it. If there is a next time I now have the process.
Hardinge Quest 51 Turret Help! pit-bull Hardinge Lathes 2 03-15-2010 08:29 AM
Need Help!- Quest 6/42 mak0 Hardinge Lathes 2 02-17-2010 09:05 AM
Need Help With Hardinge Quest 65 SDBull16 Fanuc 1 04-23-2008 11:00 AM
quest for knowledge Timtucker General Metalwork Discussion 1 04-03-2007 05:56 PM
Post for Gibbs Quest 51 sp basil1 Post Processor Files 0 05-30-2006 10:07 AM
