| Hardinge Lathes Discuss Hardinge Lathes here. |
I have a 1992 conquest 42 it seems to go to the slowest rapid speed when you go to edit you program then go to run it. If you turn machine off then back on it runs fine at 100 percent on the rapids but then if you edit the program and go to run it it goes slow only on the rapids. Any help would be great I just got this runnung last week. thanks mike |
| Should only be on power up, as long as you did that should be ok. Sounds like your missing a prep code after doing your edit. Are you starting at the beginning of the program after? Is the control seeing the G0 command? Check your Modal screen and see whats been left on. If it works after power cycling, leeds me to believe the program is turning something on and not turning it off. |
| when you are in run mode and hit the check and see what codes active they all seem to be the same but when I hit edit and dont even change anything then go to run it rapids slow and I ran 5 pcs first and they all worked fine then edit and now it goes slow |
#10
| I was a little scared to change the parameters I called hardinge they said on that year machine after edit turn the edit key to protect mode and then hold the edit key in and push spindle stop button and I can do this when it is running and this works. or if I mdi m30 that works to Thanks for the help Mike |
| NM 135 rapids in Mach3 | zaebis | Novakon Systems | 5 | 12-05-2009 10:00 AM |
| rapids | millman52 | Mach Software (ArtSoft software) | 3 | 10-31-2008 07:41 PM |
| Need Help!- All the sudden, big problems with Rapids | SpeedsCustom | LinuxCNC (formerly EMC2) | 2 | 04-24-2008 09:44 AM |
| feed and rapids | ccmind | Syil Products | 2 | 11-20-2006 09:31 PM |
| Fadal rapids | Garypl | Fadal | 5 | 11-03-2005 02:36 PM |
